[gdal-dev] Does gdal support rotated pole projections?
Alex Hagen-Zanker ahh34 at cam.ac.uk
Tue Mar 22 08:09:16 EDT 2011
Dear All,
Some climate projection data uses a rotated pole projection for gridded
data.  Is there any way in which I can get GDAL to work with this data?
In particular I would like to burn vector data from other projections
into this grid using gdal_rasterize.
Using Google I find posts of similar problems in several forums. It
appears that proj.4 uses "proj=ob_tran, etc" but GDAL does not support
this?
Thanks, Alex
Projection description:
http://ukclimateprojections-ui.defra.gov.uk/ui/docs/grids/prob_land_25km_rotated/index.php
Earlier discussion:
http://osdir.com/ml/gis.gdal.devel/2005-06/msg00054.html
