[gdal-dev] Using MEM driver to output to an gtiff in /vsimem/
Bborie Park bkpark at ucdavis.edu
Tue Mar 29 18:17:17 EDT 2011
What I'm attempting to do is write some code to do the following:
PostGIS Raster -> GDAL MEM -> user specified GDAL output format in
/vsimem/ (e.g. GTiff) -> return contents of the output file to user
I'm able to successfully create a MEM dataset with raw band data
specified using the DATAPOINTER creation option and the GDALRasterIO()
function from a PostGIS Raster.  I've been successful outputting the MEM
dataset using CreateCopy() to a GTiff stored on the filesystem (e.g.
/tmp/out.tif), such as...
rtn_ds = GDALCreateCopy(
	rtn_drv,
	"/tmp/out.tif",
	src_ds,
	FALSE,
	options,
	NULL,
	NULL
What does not seem to work is if I use CreateCopy with a /vsimem/ path.
	rtn_drv,
	"/vsimem/out.tif",
	src_ds,
	FALSE,
	options,
	NULL,
	NULL
rtn = VSIGetMemFileBuffer("/vsimem/out.tif", &j, FALSE);
When I read /vsimem/out.tif back out to pass back to the end-user, the
contents are significantly shorter than what it should be.  From what I
can tell, the contents outputted are just the tiff header information
and none of the band data.
Is there something different about outputting a raster to a filesystem
rather than /vsimem/ when working with a MEM raster with external band data?
Thanks,
Bborie
Bborie Park
Programmer
Center for Vectorborne Diseases
UC Davis
530-752-8380
