[gdal-dev] Polygon assembly has failed for feature FIDN
Frank Warmerdam
warmerdam at pobox.com
Sun May 8 09:06:16 EDT 2011
On 11-05-08 08:28 AM, Gabriel Breahna wrote:
> Hello,
> I am receiving this error into the MS_ERRORFILE log file:
> msDrawMap(): Image handling error. Failed to draw layer named 'danube'.
> msOGRFileNextShape(): OGR error. IllegalArgumentException: Points of LinearRing
> do not form a closed linestring
> The command:
> $ ogrinfo 3R7D0421.000 DEPARE
> for the bad polyline is returning:
> Warning 1: Polygon assembly has failed for feature
> FIDN=1245675120,FIDS=1.Geometry may be missing or incomplete.
> 44.080779999999997,26.75515 44.080759999999998,26.755099999999999
> 44.080750000000002))
Gabriel,
I have briefly reviewed the MapServer code for reading from OGR and it
does not *look* like a warning should terminate the feature fetching
loop. Would it be possible for you to file a ticket against MapServer
including a simple mapfile demonstrating the issue and a pointer to
the data file? Please ensure it is assigned to "warmerdam" or email
me privately after it is created.
Please be specific about the versions of GDAL/OGR and MapServer you
are using.
> With the same file OpenCPN is working/rendering fine.
> Any idea how to do in order to be able to show this layer?
I'm guessing that OpenCPN is just less sensitive to the problem in the
data.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
