[gdal-dev] GetProjectionRef() returning NULL
Frank Warmerdam
warmerdam at pobox.com
Mon May 9 12:55:14 EDT 2011
On 11-05-09 10:37 AM, Rodolfo Bonnin wrote:
> Hello all,
> I'm working with a HDF5 dataset with Gdal 1.8.0, I open it with the
> HDF5Image driver.
> The image metadata is read OK from what I can see, but when I want to
> execute the GetProjectionRef() method, it returns null, even if the
> documentation says it wouldn't return any null pointer.
> I've traced the null pointer to HDF5ImageDataset::CreateProjections(),
> in line 562 it reads
> _______________________________________________________________________
> poH5Objects=HDF5FindDatasetObjects( poH5RootGroup, "Latitude" );
> if( !poH5Objects ) {
> return CE_None;
> Since my HDF5 file doesn't have a "Latitude" dataset, the function
> returns without setting the pszProjection variable, it remains null
> and is never being set as an empty string, as the GetProjectionRef
> consist only in:
> ________________________________________________________________________
> const char *HDF5ImageDataset::GetProjectionRef( )
> return pszProjection; //
Rodolfo,
I agree, this is a bug. I have filed a ticket on the issue and applied a
fix in 1.8 and trunk.
http://trac.osgeo.org/gdal/ticket/4076
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
