[gdal-dev] Segmentation fault with debian install of gdal on MODIS hdf4 files
Nikolaos Hatzopoulos nhatzop at gmail.com
Mon May 9 23:23:57 EDT 2011
I am using centos and elgis repo and for me it is working..
so there must be a problem with the hdf linking or compile of the library.
Note hdf4 is responsible to do the job not hdf5 for the particular case.
 gdal_translate 'HDF4_EOS:EOS_GRID:"MCD15A2.
A2002185.h12v05.005.2007172035551.hdf":MOD_Grid_MOD15A2:LaiStdDev_1km'
test2.tif
Input file size is 1200, 1200
0...10...20...30...40...50...60...70...80...90...100 - done.
--Nikos Hatzopoulos
On Mon, May 9, 2011 at 5:56 PM, Jonathan Greenberg <greenberg at ucdavis.edu>wrote:
> Folks:
> I did a Debian install of both the "unstable" and the "experimental"
> versions of GDAL, and when running gdal_translate on a MODIS HDF4 file
> I'm getting a segmentation fault.  gdalinfo works fine tho.  Thoughts?
> $ gdal_translate -ot Float32 -of ENVI
> HDF4_EOS:EOS_GRID:MCD15A2.A2002185.h35v10.005.2007177210333.hdf:MOD_Grid_MOD15A2:Lai_1km
> test_hdf.envi
> 0Segmentation fault
> $ gdalinfo
> Driver: HDF4Image/HDF4 Dataset
> Files: MCD15A2.A2002185.h35v10.005.2007177210333.hdf
> Size is 1200, 1200
> Coordinate System is:
> PROJCS["unnamed",
>    GEOGCS["Unknown datum based upon the custom spheroid",
>        DATUM["Not specified (based on custom spheroid)",
>            SPHEROID["Custom spheroid",6371007.181,0]],
>        PRIMEM["Greenwich",0],
>        UNIT["degree",0.0174532925199433]],
>    PROJECTION["Sinusoidal"],
>    PARAMETER["longitude_of_center",0],
>    PARAMETER["false_easting",0],
>    PARAMETER["false_northing",0],
>    UNIT["Meter",1]]
> Origin = (18903158.834332998842001,-1111950.519667000044137)
> Pixel Size = (926.625433055833014,-926.625433054999803)
> Metadata:
>  HDFEOSVersion=HDFEOS_V2.9
>  LOCALGRANULEID=MCD15A2.A2002185.h35v10.005.2007177210333.hdf
>  PRODUCTIONDATETIME=2007-06-26T21:03:33.000Z
>  DAYNIGHTFLAG=Day
>  REPROCESSINGACTUAL=reprocessed
>  LOCALVERSIONID=5.0.4
>  REPROCESSINGPLANNED=further update is anticipated
>  SCIENCEQUALITYFLAG=Not Investigated
>  AUTOMATICQUALITYFLAGEXPLANATION=No automatic quality assessment is
> performed in the PGE
>  AUTOMATICQUALITYFLAG=Passed
>  SCIENCEQUALITYFLAGEXPLANATION=See
> http://landweb.nascom/nasa.gov/cgi-bin/QA_WWW/qaFlagPage.cgi?sat=aqua
> the product Science Quality status.
>  QAPERCENTMISSINGDATA=99
>  QAPERCENTOUTOFBOUNDSDATA=99
>  QAPERCENTCLOUDCOVER=0
>  QAPERCENTINTERPOLATEDDATA=0
>  PARAMETERNAME=MCD15A2
>  VERSIONID=5
>  SHORTNAME=MCD15A2
>  INPUTPOINTER=MYD15A1.A2002192.h35v10.005.2007162232536.hdf,
> MYD15A1.A2002191.h35v10.005.2007162024118.hdf,
> MYD15A1.A2002190.h35v10.005.2007162092900.hdf,
> MYD15A1.A2002189.h35v10.005.2007161211830.hdf,
> MYD15A1.A2002188.h35v10.005.2007161122622.hdf,
> MYD15A1.A2002187.h35v10.005.2007161050931.hdf,
> MYD15A1.A2002186.h35v10.005.2007161012141.hdf,
> MYD15A1.A2002185.h35v10.005.2007161153557.hdf,
> MOD15A1.A2002192.h35v10.005.2007163022444.hdf,
> MOD15A1.A2002191.h35v10.005.2007162214105.hdf,
> MOD15A1.A2002190.h35v10.005.2007162180320.hdf,
> MOD15A1.A2002189.h35v10.005.2007161200152.hdf,
> MOD15A1.A2002188.h35v10.005.2007161164154.hdf,
> MOD15A1.A2002187.h35v10.005.2007160174423.hdf,
> MOD15A1.A2002186.h35v10.005.2007152183046.hdf,
> MOD15A1.A2002185.h35v10.005.2007152031253.hdf, MCD15A2_ANC_RI4.hdf
>  GRINGPOINTLONGITUDE=172.479315908761, 172.622770159185,
> 179.999502554976, -179.856407114504
>  GRINGPOINTLATITUDE=-19.1662177463598, -9.98364248250805,
> -9.97534112170732, -19.180676222654
>  GRINGPOINTSEQUENCENO=1, 2, 3, 4
>  EXCLUSIONGRINGFLAG=N
>  RANGEENDINGDATE=2002-07-11
>  RANGEENDINGTIME=23:59:59
>  RANGEBEGINNINGDATE=2002-07-04
>  RANGEBEGINNINGTIME=00:00:00
>  PGEVERSION=5.0.6
>  ASSOCIATEDSENSORSHORTNAME=MODIS
>  ASSOCIATEDPLATFORMSHORTNAME=Terra
>  ASSOCIATEDINSTRUMENTSHORTNAME=MODIS
>  ASSOCIATEDPLATFORMSHORTNAME=Aqua
>  QAPERCENTGOODQUALITY=89
>  QAPERCENTOTHERQUALITY=100
>  HORIZONTALTILENUMBER=35
>  VERTICALTILENUMBER=10
>  TileID=51035010
>  NDAYS_COMPOSITED=16
>  QAPERCENTGOODFPAR=89
>  QAPERCENTGOODLAI=89
>  QAPERCENTMAINMETHOD=89
>  QAPERCENTEMPIRICALMODEL=11
>  NORTHBOUNDINGCOORDINATE=-9.99999999910197
>  SOUTHBOUNDINGCOORDINATE=-19.1833333316106
>  EASTBOUNDINGCOORDINATE=179.999999983337
>  WESTBOUNDINGCOORDINATE=172.622524004598
>  ALGORITHMPACKAGEACCEPTANCEDATE=10-01-2004
>  ALGORITHMPACKAGEMATURITYCODE=Normal
>  ALGORITHMPACKAGENAME=MCDPR_15A2
>  ALGORITHMPACKAGEVERSION=5
>  GEOANYABNORMAL=False
>  GEOESTMAXRMSERROR=50.0
>  LONGNAME=MODIS/Terra+Aqua Leaf Area Index/FPAR 8-Day L4 Global 1km SIN
> Grid
>  PROCESSINGCENTER=MODAPS
>  SYSTEMFILENAME=MYD15A1.A2002192.h35v10.005.2007162232536.hdf,
>  NUMBEROFGRANULES=1
>  GRANULEDAYNIGHTFLAG=Day
>  GRANULEBEGINNINGDATETIME=2007-06-01T03:12:53.000Z
>  GRANULEENDINGDATETIME=2007-06-01T03:12:53.000Z
>  CHARACTERISTICBINANGULARSIZE=30.0
>  CHARACTERISTICBINSIZE=926.625433055556
>  DATACOLUMNS=1200
>  DATAROWS=1200
>  GLOBALGRIDCOLUMNS=43200
>  GLOBALGRIDROWS=21600
>  NADIRDATARESOLUTION=1km
>  MAXIMUMOBSERVATIONS=1
>  SPSOPARAMETERS=5367, 2680
>  PROCESSINGENVIRONMENT=IRIX64 mtvs3 6.5 10070055 IP35
>  DESCRREVISION=5.0
>  ENGINEERING_DATA=
> # MOD_PR15A2 (Vers 5.0.4 Rele 10.18.2006 23:59)
> # MUM API Vers 2.5.8 Rev 104 Rel. 11.15.2000 10:49 (pgs)
> # (c) 2000 J.M. Glassy, NTSG,LLSD
> # portions of MUM API by Petr Votava,NTSG Lab,U.Montana
> # HOST ECS_PGS_VirtualHost PROCESS 19540618
> # PLATFORM Sys genericunix Vers unknown Release unknown Node (no
> nodename available)
> # INIT-TIME Tue Jun 26 17:00:14 2007
> YEARDAY 185 COMPOSITE_PERIOD  24 FIRSTDAY_IN_PERIOD 185
> SDS[PGE34_ISG_MBRLUT] ID 268697600 Rank   2 (664 120)
> SDS[PGE34_OUTFIELD_PROP] ID 268697601 Rank   2 (78 179)
> SDS[PGE34_BROWSEFIELD_PROP] ID 268697602 Rank   2 (77 164)
> READANC SDS[PGE34_ISG_MBRLUT] RANK 2 (664 120)
> READANC SDS[PGE34_OUTFIELD_PROP] RANK 2 (78 179)
> READANC SDS[PGE34_BROWSEFIELD_PROP] RANK 2 (77 164)
> READANC SDS[PGE34_ECSMETA_DICT] RANK 2 (73 110)
> READANC SDS[PGE34_RELEASE_NOTES] RANK 2 (84 98)
> FLDPROP SDSnam(PGE34_OUTFIELD_PROP)MoleName(PGE34_OUTFIELD_PROP)Status
> 3 Nelem 13962
> BROWSE cvlBrwMol 0 Nelem 57600 Type 21 Status 3
> BROWSE cvlBrwMol 1 Nelem 57600 Type 21 Status 3
> BROWSE cvlBrwMol 2 Nelem 57600 Type 21 Status 3
> BROWSE cvlBrwMol 3 Nelem 57600 Type 21 Status 3
> BROWSE: NEW GRID ID 4194320
> BROWSEFIELD  0 Sum 14571961 Average 252.985
> BROWSEFIELD  1 Sum 14560181 Average 252.781
> BROWSEFIELD  2 Sum 8999599 Average 156.243
> BROWSEFIELD  3 Sum 14616929 Average 253.766
> BROWSE-DONE: N-Pixels 57600 Invalid offsets: 0 OutOfRange 0
> COMPOSITING FPAR FREQUENCIES
> FPAR   6       33
> FPAR   7       20
> FPAR   8       11
> FPAR   9        7
> FPAR  10       18
> FPAR  11        3
> FPAR  12        7
> FPAR  13       14
> FPAR  14        9
> FPAR  15       21
> FPAR  16       15
> FPAR  17        4
> FPAR  18       10
> FPAR  19       50
> FPAR  20       24
> FPAR  21       11
> FPAR  22       13
> FPAR  23        7
> FPAR  24       26
> FPAR  25       23
> FPAR  26       22
> FPAR  27       37
> FPAR  28       26
> FPAR  29       21
> FPAR  30       33
> FPAR  31       17
> FPAR  32       33
> FPAR  33       23
> FPAR  34       17
> FPAR  35       27
> FPAR  36       22
> FPAR  37       17
> FPAR  38       35
> FPAR  39       18
> FPAR  40       35
> FPAR  41       30
> FPAR  42       25
> FPAR  43       17
> FPAR  44       38
> FPAR  45       22
> FPAR  46       27
> FPAR  47       37
> FPAR  48       45
> FPAR  49       21
> FPAR  50       29
> FPAR  51       39
> FPAR  52       37
> FPAR  53       38
> FPAR  54       33
> FPAR  55       40
> FPAR  56       26
> FPAR  57       27
> FPAR  58       40
> FPAR  59       54
> FPAR  60       54
> FPAR  61       55
> FPAR  62       51
> FPAR  63       27
> FPAR  64       66
> FPAR  65       66
> FPAR  66       66
> FPAR  67       56
> FPAR  68       57
> FPAR  69       78
> FPAR  70       67
> FPAR  71       65
> FPAR  72       69
> FPAR  73       82
> FPAR  74       75
> FPAR  75       79
> FPAR  76      101
> FPAR  77       52
> FPAR  78       68
> FPAR  79       78
> FPAR  80       73
> FPAR  81       57
> FPAR  82       62
> FPAR  83       97
> FPAR  84      137
> FPAR  85      213
> FPAR  86      170
> FPAR  87      243
> FPAR  88      410
> FPAR  89     1142
> FPAR  90     2373
> FPAR  91      758
> FPAR  92       68
> FPAR  93      125
> FPAR  94      179
> FPAR  95      187
> FPAR  96      126
> FPAR  97       31
> FPAR  98       13
> FPAR  99        4
> COMPOSITING LAI FREQUENCIES
> LAI    1       68
> LAI    2       53
> LAI    3      131
> LAI    4       56
> LAI    5      109
> LAI    6      114
> LAI    7      112
> LAI    8       85
> LAI    9       96
> LAI   10       98
> LAI   11      107
> LAI   12       75
> LAI   13       80
> LAI   14      104
> LAI   15       93
> LAI   16      135
> LAI   17       71
> LAI   18       95
> LAI   19       97
> LAI   20      103
> LAI   21      106
> LAI   22       90
> LAI   23       95
> LAI   24      122
> LAI   25       94
> LAI   26       66
> LAI   27       68
> LAI   28       71
> LAI   29       39
> LAI   30       53
> LAI   31       38
> LAI   32       35
> LAI   33       48
> LAI   34       50
> LAI   35       40
> LAI   36       46
> LAI   37       44
> LAI   38       59
> LAI   39       79
> LAI   40       76
> LAI   41       99
> LAI   42       66
> LAI   43       64
> LAI   44       50
> LAI   45       50
> LAI   46       71
> LAI   47       50
> LAI   48       73
> LAI   49      130
> LAI   50       89
> LAI   51      115
> LAI   52       79
> LAI   53      116
> LAI   54      160
> LAI   55      191
> LAI   56      339
> LAI   57      390
> LAI   58      272
> LAI   59      263
> LAI   60     1178
> LAI   61      225
> LAI   62      211
> LAI   63      273
> LAI   64      358
> LAI   65      142
> LAI   66      107
> LAI   67      449
> LAI   68       57
> LAI   69      246
> COMPOSITING DAY INDEX FREQUENCIES
> TILE-INDEX    0 Selection Frequency:      205
> TILE-INDEX    1 Selection Frequency:     1166
> TILE-INDEX    2 Selection Frequency:      732
> TILE-INDEX    3 Selection Frequency:     1987
> TILE-INDEX    4 Selection Frequency:      524
> TILE-INDEX    5 Selection Frequency:      886
> TILE-INDEX    6 Selection Frequency:       29
> TILE-INDEX    7 Selection Frequency:      566
> TILE-INDEX    8 Selection Frequency:      469
> TILE-INDEX    9 Selection Frequency:      740
> TILE-INDEX   10 Selection Frequency:     1224
> TILE-INDEX   11 Selection Frequency:      343
> TILE-INDEX   12 Selection Frequency:      146
> TILE-INDEX   13 Selection Frequency:       97
> TILE-INDEX   14 Selection Frequency:        0
> TILE-INDEX   15 Selection Frequency:        0
> LOCALGRANULEID [MCD15A2.A2002185.h35v10.005.2007177210333.hdf]
> ECS QC PERCENT N valid (demominator) : 9114.000000
> ECS Total Pixels       (denominator) : 1440000
> QAPERCENTxx PSA BEFORE CALC
> QAPERCENTINTERPOLATEDDATA: 0
> QAPERCENTMISSINGDATA     : 1430886
> QAPERCENTOUTOFBOUNDSDATA : 1430886
> QAPERCENTCLOUDCOVER      : 487
> QAPERCENTNOTPRODUCEDCLOUD: 0
> QAPERCENTNOTPRODUCEDOTHER: 0
> QAPERCENTGOODQUALITY     : 8135
> QAPERCENTOTHERQUALITY    : 1431865
> QAPERCENTGOODFPAR        : 8135
> QAPERCENTGOODLAI         : 8135
> QAPERCENTMAINMETHOD      : 8135
> QAPERCENTEMPIRICALMODEL  : 979
> QAPERCENTNDAYSCOMPOSITED : 16
> QAPERCENTTERRA           : 5527
> QAPERCENTxx PSA AFTER CALC
> QAPERCENTMISSINGDATA     : 99
> QAPERCENTOUTOFBOUNDSDATA : 99
> QAPERCENTCLOUDCOVER      : 0
> QAPERCENTGOODQUALITY     : 89
> QAPERCENTOTHERQUALITY    : 100
> QAPERCENTGOODFPAR        : 89
> QAPERCENTGOODLAI         : 89
> QAPERCENTMAINMETHOD      : 89
> QAPERCENTEMPIRICALMODEL  : 11
> SESSION ENGINEERING SUMMARY FOR PGE34 8-day FPAR,LAI
> UM_VERSION U.MONTANA MODIS PGE34 Vers 5.0.4 Rev 4 Release 10.18.2006 23:59
> Candidate Days: 16
> N. invalid loads      : 0
> Pixels failing best day : 1430886
> Pixels set to fill      : 0
> Pixels skipped (disqual): 22915542
> Unclassified Pixels     : 1430886
> MOD15A1 DAILY Input:
> /MODAPSops3/archive/f46/running/AMPM_L10/16495460/MOD15A1.A2002185.h35v10.005.2007152031253.hdf
> /MODAPSops3/archive/f46/running/AMPM_L10/16495460/MOD15A1.A2002186.h35v10.005.2007152183046.hdf
> /MODAPSops3/archive/f46/running/AMPM_L10/16495460/MOD15A1.A2002187.h35v10.005.2007160174423.hdf
> /MODAPSops3/archive/f46/running/AMPM_L10/16495460/MOD15A1.A2002188.h35v10.005.2007161164154.hdf
> /MODAPSops3/archive/f46/running/AMPM_L10/16495460/MOD15A1.A2002189.h35v10.005.2007161200152.hdf
> /MODAPSops3/archive/f46/running/AMPM_L10/16495460/MOD15A1.A2002190.h35v10.005.2007162180320.hdf
> /MODAPSops3/archive/f46/running/AMPM_L10/16495460/MOD15A1.A2002191.h35v10.005.2007162214105.hdf
> /MODAPSops3/archive/f46/running/AMPM_L10/16495460/MOD15A1.A2002192.h35v10.005.2007163022444.hdf
> /MODAPSops3/archive/f46/running/AMPM_L10/16495460/MYD15A1.A2002185.h35v10.005.2007161153557.hdf
> /MODAPSops3/archive/f46/running/AMPM_L10/16495460/MYD15A1.A2002186.h35v10.005.2007161012141.hdf
> /MODAPSops3/archive/f46/running/AMPM_L10/16495460/MYD15A1.A2002187.h35v10.005.2007161050931.hdf
> /MODAPSops3/archive/f46/running/AMPM_L10/16495460/MYD15A1.A2002188.h35v10.005.2007161122622.hdf
> /MODAPSops3/archive/f46/running/AMPM_L10/16495460/MYD15A1.A2002189.h35v10.005.2007161211830.hdf
> /MODAPSops3/archive/f46/running/AMPM_L10/16495460/MYD15A1.A2002190.h35v10.005.2007162092900.hdf
> /MODAPSops3/archive/f46/running/AMPM_L10/16495460/MYD15A1.A2002191.h35v10.005.2007162024118.hdf
> /MODAPSops3/archive/f46/running/AMPM_L10/16495460/MYD15A1.A2002192.h35v10.005.2007162232536.hdf
> PGE34 Output       :
> /MODAPSops3/archive/f46/running/AMPM_L10/16495460/MCD15A2.1.2002-185T00:00:00.000000Z.51035010.18515794.215230_1.hdf
> MOD15A2 ANCILLARY    : /MODAPSops3/PGE/AMPM/coeff/PGE34/MCD15A2_ANC_RI4.hdf
> QAPERCENTTERRA          : 61
> Started Tue Jun 26 17:00:14 2007  Ended Tue Jun 26 17:03:33 2007
> Elapsed Time         199 Sec (       3.32 Min)
>  MOD15A2_FILLVALUE_DOC=MOD15A2 FILL VALUE LEGEND
> 255 = _Fillvalue, assigned when:
>    * the MODAGAGG suf. reflectance for channel VIS, NIR was assigned
> its _Fillvalue, or
>    * land cover pixel itself was assigned _Fillvalus 255 or 254.
> 254 = land cover assigned as perennial salt or inland fresh water.
> 253 = land cover assigned as barren, sparse vegetation (rock, tundra,
> desert.)
> 252 = land cover assigned as perennial snow, ice.
> 251 = land cover assigned as "permanent" wetlands/inundated marshlands.
> 250 = land cover assigned as urban/built-up.
> 249 = land cover assigned as "unclassified" or not able to determine.
>  MOD15A2_FparLai_QC_DOC=
> FparLai_QC 5 BITFIELDS IN 8 BITWORD
> MODLAND_QC START 0 END 0 VALIDS 2
> MODLAND_QC   0 = Good Quality (main algorithm with or without saturation)
> MODLAND_QC   1 = Other Quality (back-up algorithm or fill value)
> SENSOR START 1 END 1 VALIDS 2
> SENSOR       0  = Terra
> SENSOR       1  = Aqua
> DEADDETECTOR START 2 END 2 VALIDS 2
> DEADDETECTOR 0 = Detectors apparently fine for up to 50% of channels 1,2
> DEADDETECTOR 1 = Dead detectors caused >50% adjacent detector retrieval
> CLOUDSTATE START 3 END 4 VALIDS 4 (this inherited from Aggregate_QC
> bits {0,1} cloud state)
> CLOUDSTATE   00 = 0 Significant clouds NOT present (clear)
> CLOUDSTATE   01 = 1 Significant clouds WERE present
> CLOUDSTATE   10 = 2 Mixed cloud present on pixel
> CLOUDSTATE   11 = 3 Cloud state not defined,assumed clear
> SCF_QC START 5 END 7 VALIDS 5
> SCF_QC       000=0 Main (RT) algorithm used, best result possible (no
> saturation)
> SCF_QC       001=1 Main (RT) algorithm used, saturation occured. Good,
> very usable.
> SCF_QC       010=2 Main algorithm failed due to bad geometry,
> empirical algorithm used
> SCF_QC       011=3 Main algorithm faild due to problems other than
> geometry, empirical algorithm used
> SCF_QC       100=4 Pixel not produced at all, value coudn't be
> retrieved (possible reasons: bad L1B data, unusable MODAGAGG data)
>  MOD15A2_FparExtra_QC_DOC=
> FparExtra_QC 6 BITFIELDS IN 8 BITWORD
> LANDSEA PASS-THROUGH START 0 END 1 VALIDS 4
> LANDSEA   00 = 0 LAND       AggrQC(3,5)values{001}
> LANDSEA   01 = 1 SHORE      AggrQC(3,5)values{000,010,100}
> LANDSEA   10 = 2 FRESHWATER AggrQC(3,5)values{011,101}
> LANDSEA   11 = 3 OCEAN      AggrQC(3,5)values{110,111}
> SNOW_ICE (from Aggregate_QC bits) START 2 END 2 VALIDS 2
> SNOW_ICE  0 = No snow/ice detected
> SNOW_ICE  1 = Snow/ice were detected
> AEROSOL START 3 END 3 VALIDS 2
> AEROSOL   0 = No or low atmospheric aerosol levels detected
> AEROSOL   1 = Average or high aerosol levels detected
> CIRRUS (from Aggregate_QC bits {8,9} ) START 4 END 4 VALIDS 2
> CIRRUS    0 = No cirrus detected
> CIRRUS    1 = Cirrus was detected
> INTERNAL_CLOUD_MASK START 5 END 5 VALIDS 2
> INTERNAL_CLOUD_MASK 0 = No clouds
> INTERNAL_CLOUD_MASK 1 = Clouds were detected
> CLOUD_SHADOW START 6 END 6 VALIDS 2
> CLOUD_SHADOW        0 = No cloud shadow detected
> CLOUD_SHADOW        1 = Cloud shadow detected
> SCF_BIOME_MASK START 7 END 7 VALIDS 2
> SCF_BIOME_MASK  0 = Biome outside interval <1,4>
> SCF_BIOME_MASK  1 = Biome in interval <1,4>
>  MOD15A2_StdDev_QC_DOC=MOD15A2 STANDARD DEVIATION FILL VALUE LEGEND
> its _Fillvalue, or
> desert.)
> 248 = no standard deviation available, pixel produced using backup method.
>  MOD15A1_ANC_BUILD_CERT=mtAncUtil v. 1.8 Rel. 09.11.2000 17:36 API v.
> 2.5.6 release 09.14.2000 16:33 Rev.Index 102 (J.Glassy)
>  UM_VERSION=U.MONTANA MODIS PGE34 Vers 5.0.4 Rev 4 Release 10.18.2006 23:59
>  scale_factor=0.1
>  scale_factor_err=0
>  add_offset=0
>  add_offset_err=0
>  calibrated_nt=21
>  valid_range=0, 100
>  _FillValue=255
>  long_name=MCD15A2 MODIS/Terra+Aqua Gridded 1KM Leaf Area Index LAI
> (8-day composite)
>  units=m^2/m^2
> its _Fillvalue, or
> desert.)
> Corner Coordinates:
> Upper Left  (18903158.834,-1111950.520) (172d37'21.09"E, 10d 0' 0.00"S)
> Lower Left  (18903158.834,-2223901.039) (179d 5'23.20"W, 20d 0' 0.00"S)
> Upper Right (20015109.354,-1111950.520) (177d13'23.56"W, 10d 0' 0.00"S)
> Lower Right (20015109.354,-2223901.039) (168d26'52.80"W, 20d 0' 0.00"S)
> Center      (19459134.094,-1667925.779) (178d49'36.01"W, 15d 0' 0.00"S)
> Band 1 Block=1200x100 Type=Byte, ColorInterp=Gray
>  Description = MCD15A2 MODIS/Terra+Aqua Gridded 1KM Leaf Area Index
> LAI (8-day composite)
>  NoData Value=255
>  Unit Type: m^2/m^2
>  Offset: 0,   Scale:0.1
> Jonathan A. Greenberg, PhD
> Assistant Project Scientist
> Center for Spatial Technologies and Remote Sensing (CSTARS)
> Department of Land, Air and Water Resources
> University of California, Davis
> One Shields Avenue
> Davis, CA 95616
> Phone: 415-763-5476
> AIM: jgrn307, MSN: jgrn307 at hotmail.com, Gchat: jgrn307
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110509/ff899b82/attachment-0001.html
