[gdal-dev] Segmentation fault with debian install of gdal on
MODIS hdf4 files
Jonathan Greenberg
greenberg at ucdavis.edu
Tue May 10 15:24:21 EDT 2011
Thanks, but I was hoping someone had seen this with the latest Debian
release. Follow-up question, if I were to uninstall gdal + all the
affiliated libraries/dependencies, what do I need to make sure I
remove? I'm noticing, at least, that the segfault is not occurring on
another debian box we have -- seems like something may have gotten
corrupted along the way, but I've tried doing an apt-get remove on
libgdal1-dev and gdal-bin, as well as the libhdf4. Any tricks to
"clearing out" gdal for a "clean" reinstall?
--j
On Mon, May 9, 2011 at 8:23 PM, Nikolaos Hatzopoulos <nhatzop at gmail.com> wrote:
> I am using centos and elgis repo and for me it is working..
> so there must be a problem with the hdf linking or compile of the library.
> Note hdf4 is responsible to do the job not hdf5 for the particular case.
> gdal_translate 'HDF4_EOS:EOS_GRID:"MCD15A2.
> A2002185.h12v05.005.2007172035551.hdf":MOD_Grid_MOD15A2:LaiStdDev_1km'
> test2.tif
> Input file size is 1200, 1200
> 0...10...20...30...40...50...60...70...80...90...100 - done.
> --Nikos Hatzopoulos
> On Mon, May 9, 2011 at 5:56 PM, Jonathan Greenberg <greenberg at ucdavis.edu>
> wrote:
>> Folks:
>> I did a Debian install of both the "unstable" and the "experimental"
>> versions of GDAL, and when running gdal_translate on a MODIS HDF4 file
>> I'm getting a segmentation fault. gdalinfo works fine tho. Thoughts?
>> $ gdal_translate -ot Float32 -of ENVI
>> HDF4_EOS:EOS_GRID:MCD15A2.A2002185.h35v10.005.2007177210333.hdf:MOD_Grid_MOD15A2:Lai_1km
>> test_hdf.envi
>> 0Segmentation fault
>> $ gdalinfo
>> Driver: HDF4Image/HDF4 Dataset
>> Files: MCD15A2.A2002185.h35v10.005.2007177210333.hdf
>> Size is 1200, 1200
>> Coordinate System is:
>> PROJCS["unnamed",
>> GEOGCS["Unknown datum based upon the custom spheroid",
>> DATUM["Not specified (based on custom spheroid)",
>> SPHEROID["Custom spheroid",6371007.181,0]],
>> PRIMEM["Greenwich",0],
>> UNIT["degree",0.0174532925199433]],
>> PROJECTION["Sinusoidal"],
>> PARAMETER["longitude_of_center",0],
>> PARAMETER["false_easting",0],
>> PARAMETER["false_northing",0],
>> UNIT["Meter",1]]
>> Origin = (18903158.834332998842001,-1111950.519667000044137)
>> Pixel Size = (926.625433055833014,-926.625433054999803)
>> Metadata:
>> HDFEOSVersion=HDFEOS_V2.9
>> LOCALGRANULEID=MCD15A2.A2002185.h35v10.005.2007177210333.hdf
>> PRODUCTIONDATETIME=2007-06-26T21:03:33.000Z
>> DAYNIGHTFLAG=Day
>> REPROCESSINGACTUAL=reprocessed
>> LOCALVERSIONID=5.0.4
>> REPROCESSINGPLANNED=further update is anticipated
>> SCIENCEQUALITYFLAG=Not Investigated
>> AUTOMATICQUALITYFLAGEXPLANATION=No automatic quality assessment is
>> performed in the PGE
>> AUTOMATICQUALITYFLAG=Passed
>> SCIENCEQUALITYFLAGEXPLANATION=See
>> http://landweb.nascom/nasa.gov/cgi-bin/QA_WWW/qaFlagPage.cgi?sat=aqua
>> the product Science Quality status.
>> QAPERCENTMISSINGDATA=99
>> QAPERCENTOUTOFBOUNDSDATA=99
>> QAPERCENTCLOUDCOVER=0
>> QAPERCENTINTERPOLATEDDATA=0
>> PARAMETERNAME=MCD15A2
>> VERSIONID=5
>> SHORTNAME=MCD15A2
>> INPUTPOINTER=MYD15A1.A2002192.h35v10.005.2007162232536.hdf,
>> MYD15A1.A2002191.h35v10.005.2007162024118.hdf,
>> MYD15A1.A2002190.h35v10.005.2007162092900.hdf,
>> MYD15A1.A2002189.h35v10.005.2007161211830.hdf,
>> MYD15A1.A2002188.h35v10.005.2007161122622.hdf,
>> MYD15A1.A2002187.h35v10.005.2007161050931.hdf,
>> MYD15A1.A2002186.h35v10.005.2007161012141.hdf,
>> MYD15A1.A2002185.h35v10.005.2007161153557.hdf,
>> MOD15A1.A2002192.h35v10.005.2007163022444.hdf,
>> MOD15A1.A2002191.h35v10.005.2007162214105.hdf,
>> MOD15A1.A2002190.h35v10.005.2007162180320.hdf,
>> MOD15A1.A2002189.h35v10.005.2007161200152.hdf,
>> MOD15A1.A2002188.h35v10.005.2007161164154.hdf,
>> MOD15A1.A2002187.h35v10.005.2007160174423.hdf,
>> MOD15A1.A2002186.h35v10.005.2007152183046.hdf,
>> MOD15A1.A2002185.h35v10.005.2007152031253.hdf, MCD15A2_ANC_RI4.hdf
>> GRINGPOINTLONGITUDE=172.479315908761, 172.622770159185,
>> 179.999502554976, -179.856407114504
>> GRINGPOINTLATITUDE=-19.1662177463598, -9.98364248250805,
>> -9.97534112170732, -19.180676222654
>> GRINGPOINTSEQUENCENO=1, 2, 3, 4
>> EXCLUSIONGRINGFLAG=N
>> RANGEENDINGDATE=2002-07-11
>> RANGEENDINGTIME=23:59:59
>> RANGEBEGINNINGDATE=2002-07-04
>> RANGEBEGINNINGTIME=00:00:00
>> PGEVERSION=5.0.6
>> ASSOCIATEDSENSORSHORTNAME=MODIS
>> ASSOCIATEDPLATFORMSHORTNAME=Terra
>> ASSOCIATEDINSTRUMENTSHORTNAME=MODIS
>> ASSOCIATEDPLATFORMSHORTNAME=Aqua
>> QAPERCENTGOODQUALITY=89
>> QAPERCENTOTHERQUALITY=100
>> HORIZONTALTILENUMBER=35
>> VERTICALTILENUMBER=10
>> TileID=51035010
>> NDAYS_COMPOSITED=16
>> QAPERCENTGOODFPAR=89
>> QAPERCENTGOODLAI=89
>> QAPERCENTMAINMETHOD=89
>> QAPERCENTEMPIRICALMODEL=11
>> NORTHBOUNDINGCOORDINATE=-9.99999999910197
>> SOUTHBOUNDINGCOORDINATE=-19.1833333316106
>> EASTBOUNDINGCOORDINATE=179.999999983337
>> WESTBOUNDINGCOORDINATE=172.622524004598
>> ALGORITHMPACKAGEACCEPTANCEDATE=10-01-2004
>> ALGORITHMPACKAGEMATURITYCODE=Normal
>> ALGORITHMPACKAGENAME=MCDPR_15A2
>> ALGORITHMPACKAGEVERSION=5
>> GEOANYABNORMAL=False
>> GEOESTMAXRMSERROR=50.0
>> LONGNAME=MODIS/Terra+Aqua Leaf Area Index/FPAR 8-Day L4 Global 1km SIN
>> Grid
>> PROCESSINGCENTER=MODAPS
>> SYSTEMFILENAME=MYD15A1.A2002192.h35v10.005.2007162232536.hdf,
>> NUMBEROFGRANULES=1
>> GRANULEDAYNIGHTFLAG=Day
>> GRANULEBEGINNINGDATETIME=2007-06-01T03:12:53.000Z
>> GRANULEENDINGDATETIME=2007-06-01T03:12:53.000Z
>> CHARACTERISTICBINANGULARSIZE=30.0
>> CHARACTERISTICBINSIZE=926.625433055556
>> DATACOLUMNS=1200
>> DATAROWS=1200
>> GLOBALGRIDCOLUMNS=43200
>> GLOBALGRIDROWS=21600
>> NADIRDATARESOLUTION=1km
>> MAXIMUMOBSERVATIONS=1
>> SPSOPARAMETERS=5367, 2680
>> PROCESSINGENVIRONMENT=IRIX64 mtvs3 6.5 10070055 IP35
>> DESCRREVISION=5.0
>> ENGINEERING_DATA=
>> # MOD_PR15A2 (Vers 5.0.4 Rele 10.18.2006 23:59)
>> # MUM API Vers 2.5.8 Rev 104 Rel. 11.15.2000 10:49 (pgs)
>> # (c) 2000 J.M. Glassy, NTSG,LLSD
>> # portions of MUM API by Petr Votava,NTSG Lab,U.Montana
>> # HOST ECS_PGS_VirtualHost PROCESS 19540618
>> # PLATFORM Sys genericunix Vers unknown Release unknown Node (no
>> nodename available)
>> # INIT-TIME Tue Jun 26 17:00:14 2007
>> YEARDAY 185 COMPOSITE_PERIOD 24 FIRSTDAY_IN_PERIOD 185
>> SDS[PGE34_ISG_MBRLUT] ID 268697600 Rank 2 (664 120)
>> SDS[PGE34_OUTFIELD_PROP] ID 268697601 Rank 2 (78 179)
>> SDS[PGE34_BROWSEFIELD_PROP] ID 268697602 Rank 2 (77 164)
>> READANC SDS[PGE34_ISG_MBRLUT] RANK 2 (664 120)
>> READANC SDS[PGE34_OUTFIELD_PROP] RANK 2 (78 179)
>> READANC SDS[PGE34_BROWSEFIELD_PROP] RANK 2 (77 164)
>> READANC SDS[PGE34_ECSMETA_DICT] RANK 2 (73 110)
>> READANC SDS[PGE34_RELEASE_NOTES] RANK 2 (84 98)
>> FLDPROP SDSnam(PGE34_OUTFIELD_PROP)MoleName(PGE34_OUTFIELD_PROP)Status
>> 3 Nelem 13962
>> BROWSE cvlBrwMol 0 Nelem 57600 Type 21 Status 3
>> BROWSE cvlBrwMol 1 Nelem 57600 Type 21 Status 3
>> BROWSE cvlBrwMol 2 Nelem 57600 Type 21 Status 3
>> BROWSE cvlBrwMol 3 Nelem 57600 Type 21 Status 3
>> BROWSE: NEW GRID ID 4194320
>> BROWSEFIELD 0 Sum 14571961 Average 252.985
>> BROWSEFIELD 1 Sum 14560181 Average 252.781
>> BROWSEFIELD 2 Sum 8999599 Average 156.243
>> BROWSEFIELD 3 Sum 14616929 Average 253.766
>> BROWSE-DONE: N-Pixels 57600 Invalid offsets: 0 OutOfRange 0
>> COMPOSITING FPAR FREQUENCIES
>> FPAR 6 33
>> FPAR 7 20
>> FPAR 8 11
>> FPAR 9 7
>> FPAR 10 18
>> FPAR 11 3
>> FPAR 12 7
>> FPAR 13 14
>> FPAR 14 9
>> FPAR 15 21
>> FPAR 16 15
>> FPAR 17 4
>> FPAR 18 10
>> FPAR 19 50
>> FPAR 20 24
>> FPAR 21 11
>> FPAR 22 13
>> FPAR 23 7
>> FPAR 24 26
>> FPAR 25 23
>> FPAR 26 22
>> FPAR 27 37
>> FPAR 28 26
>> FPAR 29 21
>> FPAR 30 33
>> FPAR 31 17
>> FPAR 32 33
>> FPAR 33 23
>> FPAR 34 17
>> FPAR 35 27
>> FPAR 36 22
>> FPAR 37 17
>> FPAR 38 35
>> FPAR 39 18
>> FPAR 40 35
>> FPAR 41 30
>> FPAR 42 25
>> FPAR 43 17
>> FPAR 44 38
>> FPAR 45 22
>> FPAR 46 27
>> FPAR 47 37
>> FPAR 48 45
>> FPAR 49 21
>> FPAR 50 29
>> FPAR 51 39
>> FPAR 52 37
>> FPAR 53 38
>> FPAR 54 33
>> FPAR 55 40
>> FPAR 56 26
>> FPAR 57 27
>> FPAR 58 40
>> FPAR 59 54
>> FPAR 60 54
>> FPAR 61 55
>> FPAR 62 51
>> FPAR 63 27
>> FPAR 64 66
>> FPAR 65 66
>> FPAR 66 66
>> FPAR 67 56
>> FPAR 68 57
>> FPAR 69 78
>> FPAR 70 67
>> FPAR 71 65
>> FPAR 72 69
>> FPAR 73 82
>> FPAR 74 75
>> FPAR 75 79
>> FPAR 76 101
>> FPAR 77 52
>> FPAR 78 68
>> FPAR 79 78
>> FPAR 80 73
>> FPAR 81 57
>> FPAR 82 62
>> FPAR 83 97
>> FPAR 84 137
>> FPAR 85 213
>> FPAR 86 170
>> FPAR 87 243
>> FPAR 88 410
>> FPAR 89 1142
>> FPAR 90 2373
>> FPAR 91 758
>> FPAR 92 68
>> FPAR 93 125
>> FPAR 94 179
>> FPAR 95 187
>> FPAR 96 126
>> FPAR 97 31
>> FPAR 98 13
>> FPAR 99 4
>> COMPOSITING LAI FREQUENCIES
>> LAI 1 68
>> LAI 2 53
>> LAI 3 131
>> LAI 4 56
>> LAI 5 109
>> LAI 6 114
>> LAI 7 112
>> LAI 8 85
>> LAI 9 96
>> LAI 10 98
>> LAI 11 107
>> LAI 12 75
>> LAI 13 80
>> LAI 14 104
>> LAI 15 93
>> LAI 16 135
>> LAI 17 71
>> LAI 18 95
>> LAI 19 97
>> LAI 20 103
>> LAI 21 106
>> LAI 22 90
>> LAI 23 95
>> LAI 24 122
>> LAI 25 94
>> LAI 26 66
>> LAI 27 68
>> LAI 28 71
>> LAI 29 39
>> LAI 30 53
>> LAI 31 38
>> LAI 32 35
>> LAI 33 48
>> LAI 34 50
>> LAI 35 40
>> LAI 36 46
>> LAI 37 44
>> LAI 38 59
>> LAI 39 79
>> LAI 40 76
>> LAI 41 99
>> LAI 42 66
>> LAI 43 64
>> LAI 44 50
>> LAI 45 50
>> LAI 46 71
>> LAI 47 50
>> LAI 48 73
>> LAI 49 130
>> LAI 50 89
>> LAI 51 115
>> LAI 52 79
>> LAI 53 116
>> LAI 54 160
>> LAI 55 191
>> LAI 56 339
>> LAI 57 390
>> LAI 58 272
>> LAI 59 263
>> LAI 60 1178
>> LAI 61 225
>> LAI 62 211
>> LAI 63 273
>> LAI 64 358
>> LAI 65 142
>> LAI 66 107
>> LAI 67 449
>> LAI 68 57
>> LAI 69 246
>> COMPOSITING DAY INDEX FREQUENCIES
>> TILE-INDEX 0 Selection Frequency: 205
>> TILE-INDEX 1 Selection Frequency: 1166
>> TILE-INDEX 2 Selection Frequency: 732
>> TILE-INDEX 3 Selection Frequency: 1987
>> TILE-INDEX 4 Selection Frequency: 524
>> TILE-INDEX 5 Selection Frequency: 886
>> TILE-INDEX 6 Selection Frequency: 29
>> TILE-INDEX 7 Selection Frequency: 566
>> TILE-INDEX 8 Selection Frequency: 469
>> TILE-INDEX 9 Selection Frequency: 740
>> TILE-INDEX 10 Selection Frequency: 1224
>> TILE-INDEX 11 Selection Frequency: 343
>> TILE-INDEX 12 Selection Frequency: 146
>> TILE-INDEX 13 Selection Frequency: 97
>> TILE-INDEX 14 Selection Frequency: 0
>> TILE-INDEX 15 Selection Frequency: 0
>> LOCALGRANULEID [MCD15A2.A2002185.h35v10.005.2007177210333.hdf]
>> ECS QC PERCENT N valid (demominator) : 9114.000000
>> ECS Total Pixels (denominator) : 1440000
>> QAPERCENTxx PSA BEFORE CALC
>> QAPERCENTINTERPOLATEDDATA: 0
>> QAPERCENTMISSINGDATA : 1430886
>> QAPERCENTOUTOFBOUNDSDATA : 1430886
>> QAPERCENTCLOUDCOVER : 487
>> QAPERCENTNOTPRODUCEDCLOUD: 0
>> QAPERCENTNOTPRODUCEDOTHER: 0
>> QAPERCENTGOODQUALITY : 8135
>> QAPERCENTOTHERQUALITY : 1431865
>> QAPERCENTGOODFPAR : 8135
>> QAPERCENTGOODLAI : 8135
>> QAPERCENTMAINMETHOD : 8135
>> QAPERCENTEMPIRICALMODEL : 979
>> QAPERCENTNDAYSCOMPOSITED : 16
>> QAPERCENTTERRA : 5527
>> QAPERCENTxx PSA AFTER CALC
>> QAPERCENTMISSINGDATA : 99
>> QAPERCENTOUTOFBOUNDSDATA : 99
>> QAPERCENTCLOUDCOVER : 0
>> QAPERCENTGOODQUALITY : 89
>> QAPERCENTOTHERQUALITY : 100
>> QAPERCENTGOODFPAR : 89
>> QAPERCENTGOODLAI : 89
>> QAPERCENTMAINMETHOD : 89
>> QAPERCENTEMPIRICALMODEL : 11
>> SESSION ENGINEERING SUMMARY FOR PGE34 8-day FPAR,LAI
>> UM_VERSION U.MONTANA MODIS PGE34 Vers 5.0.4 Rev 4 Release 10.18.2006 23:59
>> Candidate Days: 16
>> N. invalid loads : 0
>> Pixels failing best day : 1430886
>> Pixels set to fill : 0
>> Pixels skipped (disqual): 22915542
>> Unclassified Pixels : 1430886
>> MOD15A1 DAILY Input:
>> /MODAPSops3/archive/f46/running/AMPM_L10/16495460/MOD15A1.A2002185.h35v10.005.2007152031253.hdf
>> /MODAPSops3/archive/f46/running/AMPM_L10/16495460/MOD15A1.A2002186.h35v10.005.2007152183046.hdf
>> /MODAPSops3/archive/f46/running/AMPM_L10/16495460/MOD15A1.A2002187.h35v10.005.2007160174423.hdf
>> /MODAPSops3/archive/f46/running/AMPM_L10/16495460/MOD15A1.A2002188.h35v10.005.2007161164154.hdf
>> /MODAPSops3/archive/f46/running/AMPM_L10/16495460/MOD15A1.A2002189.h35v10.005.2007161200152.hdf
>> /MODAPSops3/archive/f46/running/AMPM_L10/16495460/MOD15A1.A2002190.h35v10.005.2007162180320.hdf
>> /MODAPSops3/archive/f46/running/AMPM_L10/16495460/MOD15A1.A2002191.h35v10.005.2007162214105.hdf
>> /MODAPSops3/archive/f46/running/AMPM_L10/16495460/MOD15A1.A2002192.h35v10.005.2007163022444.hdf
>> /MODAPSops3/archive/f46/running/AMPM_L10/16495460/MYD15A1.A2002185.h35v10.005.2007161153557.hdf
>> /MODAPSops3/archive/f46/running/AMPM_L10/16495460/MYD15A1.A2002186.h35v10.005.2007161012141.hdf
>> /MODAPSops3/archive/f46/running/AMPM_L10/16495460/MYD15A1.A2002187.h35v10.005.2007161050931.hdf
>> /MODAPSops3/archive/f46/running/AMPM_L10/16495460/MYD15A1.A2002188.h35v10.005.2007161122622.hdf
>> /MODAPSops3/archive/f46/running/AMPM_L10/16495460/MYD15A1.A2002189.h35v10.005.2007161211830.hdf
>> /MODAPSops3/archive/f46/running/AMPM_L10/16495460/MYD15A1.A2002190.h35v10.005.2007162092900.hdf
>> /MODAPSops3/archive/f46/running/AMPM_L10/16495460/MYD15A1.A2002191.h35v10.005.2007162024118.hdf
>> /MODAPSops3/archive/f46/running/AMPM_L10/16495460/MYD15A1.A2002192.h35v10.005.2007162232536.hdf
>> PGE34 Output :
>> /MODAPSops3/archive/f46/running/AMPM_L10/16495460/MCD15A2.1.2002-185T00:00:00.000000Z.51035010.18515794.215230_1.hdf
>> MOD15A2 ANCILLARY :
>> /MODAPSops3/PGE/AMPM/coeff/PGE34/MCD15A2_ANC_RI4.hdf
>> QAPERCENTTERRA : 61
>> Started Tue Jun 26 17:00:14 2007 Ended Tue Jun 26 17:03:33 2007
>> Elapsed Time 199 Sec ( 3.32 Min)
>> MOD15A2_FILLVALUE_DOC=MOD15A2 FILL VALUE LEGEND
>> 255 = _Fillvalue, assigned when:
>> * the MODAGAGG suf. reflectance for channel VIS, NIR was assigned
>> its _Fillvalue, or
>> * land cover pixel itself was assigned _Fillvalus 255 or 254.
>> 254 = land cover assigned as perennial salt or inland fresh water.
>> 253 = land cover assigned as barren, sparse vegetation (rock, tundra,
>> desert.)
>> 252 = land cover assigned as perennial snow, ice.
>> 251 = land cover assigned as "permanent" wetlands/inundated marshlands.
>> 250 = land cover assigned as urban/built-up.
>> 249 = land cover assigned as "unclassified" or not able to determine.
>> MOD15A2_FparLai_QC_DOC=
>> FparLai_QC 5 BITFIELDS IN 8 BITWORD
>> MODLAND_QC START 0 END 0 VALIDS 2
>> MODLAND_QC 0 = Good Quality (main algorithm with or without saturation)
>> MODLAND_QC 1 = Other Quality (back-up algorithm or fill value)
>> SENSOR START 1 END 1 VALIDS 2
>> SENSOR 0 = Terra
>> SENSOR 1 = Aqua
>> DEADDETECTOR START 2 END 2 VALIDS 2
>> DEADDETECTOR 0 = Detectors apparently fine for up to 50% of channels 1,2
>> DEADDETECTOR 1 = Dead detectors caused >50% adjacent detector retrieval
>> CLOUDSTATE START 3 END 4 VALIDS 4 (this inherited from Aggregate_QC
>> bits {0,1} cloud state)
>> CLOUDSTATE 00 = 0 Significant clouds NOT present (clear)
>> CLOUDSTATE 01 = 1 Significant clouds WERE present
>> CLOUDSTATE 10 = 2 Mixed cloud present on pixel
>> CLOUDSTATE 11 = 3 Cloud state not defined,assumed clear
>> SCF_QC START 5 END 7 VALIDS 5
>> SCF_QC 000=0 Main (RT) algorithm used, best result possible (no
>> saturation)
>> SCF_QC 001=1 Main (RT) algorithm used, saturation occured. Good,
>> very usable.
>> SCF_QC 010=2 Main algorithm failed due to bad geometry,
>> empirical algorithm used
>> SCF_QC 011=3 Main algorithm faild due to problems other than
>> geometry, empirical algorithm used
>> SCF_QC 100=4 Pixel not produced at all, value coudn't be
>> retrieved (possible reasons: bad L1B data, unusable MODAGAGG data)
>> MOD15A2_FparExtra_QC_DOC=
>> FparExtra_QC 6 BITFIELDS IN 8 BITWORD
>> LANDSEA PASS-THROUGH START 0 END 1 VALIDS 4
>> LANDSEA 00 = 0 LAND AggrQC(3,5)values{001}
>> LANDSEA 01 = 1 SHORE AggrQC(3,5)values{000,010,100}
>> LANDSEA 10 = 2 FRESHWATER AggrQC(3,5)values{011,101}
>> LANDSEA 11 = 3 OCEAN AggrQC(3,5)values{110,111}
>> SNOW_ICE (from Aggregate_QC bits) START 2 END 2 VALIDS 2
>> SNOW_ICE 0 = No snow/ice detected
>> SNOW_ICE 1 = Snow/ice were detected
>> AEROSOL START 3 END 3 VALIDS 2
>> AEROSOL 0 = No or low atmospheric aerosol levels detected
>> AEROSOL 1 = Average or high aerosol levels detected
>> CIRRUS (from Aggregate_QC bits {8,9} ) START 4 END 4 VALIDS 2
>> CIRRUS 0 = No cirrus detected
>> CIRRUS 1 = Cirrus was detected
>> INTERNAL_CLOUD_MASK START 5 END 5 VALIDS 2
>> INTERNAL_CLOUD_MASK 0 = No clouds
>> INTERNAL_CLOUD_MASK 1 = Clouds were detected
>> CLOUD_SHADOW START 6 END 6 VALIDS 2
>> CLOUD_SHADOW 0 = No cloud shadow detected
>> CLOUD_SHADOW 1 = Cloud shadow detected
>> SCF_BIOME_MASK START 7 END 7 VALIDS 2
>> SCF_BIOME_MASK 0 = Biome outside interval <1,4>
>> SCF_BIOME_MASK 1 = Biome in interval <1,4>
>> MOD15A2_StdDev_QC_DOC=MOD15A2 STANDARD DEVIATION FILL VALUE LEGEND
>> its _Fillvalue, or
>> desert.)
>> 248 = no standard deviation available, pixel produced using backup method.
>> MOD15A1_ANC_BUILD_CERT=mtAncUtil v. 1.8 Rel. 09.11.2000 17:36 API v.
>> 2.5.6 release 09.14.2000 16:33 Rev.Index 102 (J.Glassy)
>> UM_VERSION=U.MONTANA MODIS PGE34 Vers 5.0.4 Rev 4 Release 10.18.2006
>> 23:59
>> scale_factor=0.1
>> scale_factor_err=0
>> add_offset=0
>> add_offset_err=0
>> calibrated_nt=21
>> valid_range=0, 100
>> _FillValue=255
>> long_name=MCD15A2 MODIS/Terra+Aqua Gridded 1KM Leaf Area Index LAI
>> (8-day composite)
>> units=m^2/m^2
>> its _Fillvalue, or
>> desert.)
>> Corner Coordinates:
>> Upper Left (18903158.834,-1111950.520) (172d37'21.09"E, 10d 0' 0.00"S)
>> Lower Left (18903158.834,-2223901.039) (179d 5'23.20"W, 20d 0' 0.00"S)
>> Upper Right (20015109.354,-1111950.520) (177d13'23.56"W, 10d 0' 0.00"S)
>> Lower Right (20015109.354,-2223901.039) (168d26'52.80"W, 20d 0' 0.00"S)
>> Center (19459134.094,-1667925.779) (178d49'36.01"W, 15d 0' 0.00"S)
>> Band 1 Block=1200x100 Type=Byte, ColorInterp=Gray
>> Description = MCD15A2 MODIS/Terra+Aqua Gridded 1KM Leaf Area Index
>> LAI (8-day composite)
>> NoData Value=255
>> Unit Type: m^2/m^2
>> Offset: 0, Scale:0.1
>> Jonathan A. Greenberg, PhD
>> Assistant Project Scientist
>> Center for Spatial Technologies and Remote Sensing (CSTARS)
>> Department of Land, Air and Water Resources
>> University of California, Davis
>> One Shields Avenue
>> Davis, CA 95616
>> Phone: 415-763-5476
>> AIM: jgrn307, MSN: jgrn307 at hotmail.com, Gchat: jgrn307
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
One Shields Avenue
Davis, CA 95616
Phone: 415-763-5476
