[gdal-dev] Datum Shifts with OSR.CoordinateTransform
Armin Burger armin.burger at gmx.net
Tue May 10 05:26:42 EDT 2011
Steve
In newer versions of the WKT definition there is sometimes a TOWGS84[...] tag included which contains the 7 shifting parameters, but I don't know if this is already a standard notation and if GDAL automatically takes this into account when found.
What should normally work is to use the Proj4 notation which includes the tag
  +towgs84=.....
and then define the projection via the method
  ImportFromProj4()
armin
-------- Original-Nachricht --------
> Datum: Mon, 9 May 2011 20:07:23 -0700 (PDT)
> Von: srweal <srweal at gmail.com>
> An: gdal-dev at lists.osgeo.org
> Betreff: [gdal-dev] Datum Shifts with OSR.CoordinateTransform
> Hi all,
> I'm using the C# wrapper and GDAL/OGR binaries from Tamas' repository
> (http://vbkto.dyndns.org:1280/sdk/) and am trying to do coordinate
> transformation that includes a datum shift on a geometry.
> I'm wanting to understand how I can control what shift parameters are used
> when calling the MyGeometry.Transform(MyTransform) method.
> I have been creating the CoordinateTransform by using the basic
> constructor
> (i.e. new CoordinateTransform(SourceSR, TargetSR)) but this doesn't give
> me
> any control over the shift.  Do I need to define the shift parameters on
> the
> actual SourceSR and TargetSR?  If so, how is this best done.
> Currently I'm creating the SourceSR via the ImportFromWkt() method and
> obtaining the WKT from spatialreference.org.
> Thanks for any advice, examples or links you can provide with more
> information.
> Steve
> http://osgeo-org.1803224.n2.nabble.com/Datum-Shifts-with-OSR-CoordinateTransform-tp6346391p6346391.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
Empfehlen Sie GMX DSL Ihren Freunden und Bekannten und wir
belohnen Sie mit bis zu 50,- Euro! https://freundschaftswerbung.gmx.de
