[gdal-dev] Re: Reprojecting w/ gdalwarp .. cant figure it out
fork
forkandwait at gmail.com
Tue May 10 16:09:04 EDT 2011
Frank Warmerdam <warmerdam <at> pobox.com> writes:
> Fork,
> The problem is that you have used an ESRI style file directly under the
> mistaken impression that it is compatible with GDAL/OGR. ESRI uses a
> variation of the the WKT coordinate system format.
> Try:
> gdalwarp -s_srs utm10n.prj -t_srs ESRI::spwasth.prj \
> -co "TFW=YES" ortho_imagery/ortho_1-1_1n_s_wa033_2009_1.tif foo.tif
> The ESRI:: prefix before the filename tells GDAL/OGR to convert from
> ESRI format into "normal" WKT.
Frank,
That seems to work, though I might have to wait to overlay it for now.
Thanks so much! I love GDAL!
