[gdal-dev] Matching two rasters
Even Rouault
even.rouault at mines-paris.org
Fri May 13 16:17:46 EDT 2011
Le vendredi 13 mai 2011 21:58:50, Jonathan Greenberg a écrit :
> GDALers:
> Say I have two rasters, A and B with different projections, extents,
> and resolution. I want to make B match A, such that the projection,
> resolution, and extent (filling in with some arbitrary value where
> there is no data) all match. Is there a quick way to do this using
> command line gdal tools?
Hum, you could try this 2 step process :
1) Create an empty raster that has same projection, resolution and extent than
A. Let call it C.tif
Cleaner solution : with a tiny python script.
from osgeo import gdal
src_ds = gdal.Open('A')
out_ds = gdal.GetDriverByName('GTiff').Create('C.tif', src_ds.RasterXSize,
src_ds.RasterYSize, src_ds.RasterCount)
out_ds.SetProjection(src_ds.GetProjectionRef())
out_ds.SetGeoTransform(src_ds.GetGeoTransform())
out_ds = None
Or ugly way with just gdal_translate :
gdal_translate A C.tif -scale 0 1e30
(this will force rescaling the values by 1e-30, so in practice nullifying the
data if you work with non-floating point sources)
2) gdalwarp B C.tif
This will 'copy' and reproject if necessary the content of B in C.tif using
its projections, extents, and resolution
> --j
