R: RE: [gdal-dev] GDAL build problems under Linux debian x86_64
sigfrido at tiscali.it sigfrido at tiscali.it
Mon May 16 04:28:00 EDT 2011
Hi all,
also setting the CONFIGURE_SHELL variable before running
configure worked for me:
CONFIGURE_SHELL=/bin/bash
export
CONFIGURE_SHELL
./configure --with-pg=/usr/bin/pg_config ...
Best
regards
Sig
----Messaggio originale----
Da: Josh.Vote at csiro.au
Data:
16/05/2011 10.00
A: <gdal-dev at lists.osgeo.org>
Ogg: RE: [gdal-dev] GDAL
Hi Antonio,
That seems to
have gotten the compiler running. For future Debian users experiencing
this problem setting SHELL=/bin/bash worked for me.
Thanks a lot
Josh
Vote
-----Original Message-----
[mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Antonio
Valentino
Sent: Monday, 16 May 2011 3:22 PM
To: gdal-dev at lists.osgeo.
org
Subject: Re: [gdal-dev] GDAL build problems under Linux debian
x86_64
I had a similar problem on ubuntu 11.04 and solved setting the
SHELL
variable in the GDALmake.opt.in as follows
-#SHELL=/usr/bin/bash
+SHELL=/usr/bin/bash
Non temiamo alcun confronto: Tiscali ha l'Adsl più veloce d'Italia!
Risparmia con Tutto Incluso Light: Voce + Adsl 20 mega a soli 17,95 € al mese per 12 mesi.
http://abbonati.tiscali.it/telefono-adsl/prodotti/tc/tuttoincluso_light/?WT.mc_id=01fw
