[gdal-dev] GDAL build problems under Linux debian x86_64
Goo Creations
goocreations at gmail.com
Mon May 16 04:53:58 EDT 2011
Hi
I still have the problem Ubuntun 10.04.
I've tried the above solutions without any sucess.
Any Ubuntu users have a solution?
Chris
On Mon, May 16, 2011 at 10:28 AM, sigfrido at tiscali.it
<sigfrido at tiscali.it>wrote:
> Hi all,
> also setting the CONFIGURE_SHELL variable before running
> configure worked for me:
> CONFIGURE_SHELL=/bin/bash
> export
> CONFIGURE_SHELL
> ./configure --with-pg=/usr/bin/pg_config ...
> Best
> regards
> Sig
> ----Messaggio originale----
> Da: Josh.Vote at csiro.au
> Data:
> 16/05/2011 10.00
> A: <gdal-dev at lists.osgeo.org>
> Ogg: RE: [gdal-dev] GDAL
> Hi Antonio,
> That seems to
> have gotten the compiler running. For future Debian users experiencing
> this problem setting SHELL=/bin/bash worked for me.
> Thanks a lot
> Josh
> Vote
> -----Original Message-----
> From: gdal-dev-bounces at lists.osgeo.org
> [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Antonio
> Valentino
> Sent: Monday, 16 May 2011 3:22 PM
> To: gdal-dev at lists.osgeo.
> org
> Subject: Re: [gdal-dev] GDAL build problems under Linux debian
> x86_64
> I had a similar problem on ubuntu 11.04 and solved setting the
> SHELL
> variable in the GDALmake.opt.in as follows
> -#SHELL=/usr/bin/bash
> +SHELL=/usr/bin/bash
> Non temiamo alcun confronto: Tiscali ha l'Adsl più veloce d'Italia!
> Risparmia con Tutto Incluso Light: Voce + Adsl 20 mega a soli 17,95 € al
> mese per 12 mesi.
> http://abbonati.tiscali.it/telefono-adsl/prodotti/tc/tuttoincluso_light/?WT.mc_id=01fw
> gdal-dev mailing list
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110516/d1faaa40/attachment.html
