[gdal-dev] GDAL build problems under Linux debian x86_64
Goo Creations
goocreations at gmail.com
Mon May 16 05:23:05 EDT 2011
I have problems with:
CONFIGURE_SHELL=/bin/bash (works!)
export (works!)
CONFIGURE_SHELL (error: CONFIGURE_SHELL: command not found)
./configure --with-pg=/usr/bin/pg_config ... (error:
configure: WARNING: you should use --build, --host, --target
checking build system type... Invalid configuration `...': machine `...' not
recognized
configure: error: /bin/bash ./config.sub ... failed
I've removed the third command and removed "..." from the last one. But it
still didn't work
Chris
On Mon, May 16, 2011 at 11:06 AM, sigfrido at tiscali.it
<sigfrido at tiscali.it>wrote:
> Hi Chris,
> I too have Ubuntu 10.04, and the CONFIGURE_SHELL solution
> worked for me. I didn't try the other solution, though.
> Sig
> Messaggio originale----
> Da: goocreations at gmail.com
> Data: 16/05/2011
> 10.53
> A: "sigfrido at tiscali.it"<sigfrido at tiscali.it>
> Cc: <Josh.
> Vote at csiro.au>, <gdal-dev at lists.osgeo.org>
> Ogg: Re: RE: [gdal-dev] GDAL
> Hi
> I still have the problem
> Ubuntun 10.04.
> I've tried the above solutions without any sucess.
> Any
> Ubuntu users have a solution?
> Chris
> On Mon, May 16, 2011 at 10:28 AM,
> > Hi all,
> > also
> setting the CONFIGURE_SHELL variable before running
> > configure worked
> for me:
> > export
> > CONFIGURE_SHELL
> Non temiamo alcun confronto: Tiscali ha l'Adsl più veloce d'Italia!
> Risparmia con Tutto Incluso Light: Voce + Adsl 20 mega a soli 17,95 € al
> mese per 12 mesi.
> http://abbonati.tiscali.it/telefono-adsl/prodotti/tc/tuttoincluso_light/?WT.mc_id=01fw
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110516/9d37e06e/attachment-0001.html
