[gdal-dev] GDAL build problems under Linux debian x86_64
Antonio Valentino
antonio.valentino at tiscali.it
Mon May 16 05:30:23 EDT 2011
Hi Goo Creations,
Il giorno Mon, 16 May 2011 11:23:05 +0200
Goo Creations <goocreations at gmail.com> ha scritto:
> I have problems with:
> CONFIGURE_SHELL=/bin/bash (works!)
> export (works!)
> CONFIGURE_SHELL (error: CONFIGURE_SHELL: command not found)
> ./configure --with-pg=/usr/bin/pg_config ... (error:
$ export CONFIGURE_SHELL <ENTER>
is a single command (all on the same line)
> configure: WARNING: you should use --build, --host, --target
> checking build system type... Invalid configuration `...': machine
> `...' not recognized
> configure: error: /bin/bash ./config.sub ... failed
> I've removed the third command and removed "..." from the last one.
> But it still didn't work
> Chris
> On Mon, May 16, 2011 at 11:06 AM, sigfrido at tiscali.it
> <sigfrido at tiscali.it>wrote:
> > Hi Chris,
> > I too have Ubuntu 10.04, and the CONFIGURE_SHELL solution
> > worked for me. I didn't try the other solution, though.
> > Sig
> > Messaggio originale----
> > Da: goocreations at gmail.com
> > Data: 16/05/2011
> > 10.53
> > A: "sigfrido at tiscali.it"<sigfrido at tiscali.it>
> > Cc: <Josh.
> > Vote at csiro.au>, <gdal-dev at lists.osgeo.org>
> > Ogg: Re: RE: [gdal-dev] GDAL
> > Hi
> > I still have the problem
> > Ubuntun 10.04.
> > I've tried the above solutions without any sucess.
> > Any
> > Ubuntu users have a solution?
> > Chris
> > On Mon, May 16, 2011 at 10:28 AM,
> > > Hi all,
> > > also
> > setting the CONFIGURE_SHELL variable before running
> > > configure worked
> > for me:
> > > export
> > > CONFIGURE_SHELL
> > Non temiamo alcun confronto: Tiscali ha l'Adsl più veloce d'Italia!
> > Risparmia con Tutto Incluso Light: Voce + Adsl 20 mega a soli 17,95
> > € al mese per 12 mesi.
> > http://abbonati.tiscali.it/telefono-adsl/prodotti/tc/tuttoincluso_light/?WT.mc_id=01fw
Antonio Valentino
