[gdal-dev] GDAL build problems under Linux debian x86_64
Goo Creations goocreations at gmail.com
Mon May 16 05:47:27 EDT 2011
Hi
No my configuration works perfectly, but I still get the same problem with
make. I've also tried to replace the libtool, without any success.
I was able to build the stable 1.8 without any problems. Is this a problem
in the trunk version that will be fixed,so should I wait for an update, or
is this permanent and I should try to find a solution?
Chris
On Mon, May 16, 2011 at 11:30 AM, Antonio Valentino <
antonio.valentino at tiscali.it> wrote:
> Hi Goo Creations,
> Il giorno Mon, 16 May 2011 11:23:05 +0200
> Goo Creations <goocreations at gmail.com> ha scritto:
> > I have problems with:
> > CONFIGURE_SHELL=/bin/bash     (works!)
> > export    (works!)
> > CONFIGURE_SHELL   (error: CONFIGURE_SHELL: command not found)
> > ./configure --with-pg=/usr/bin/pg_config ...    (error:
> $ export CONFIGURE_SHELL <ENTER>
> is a single command (all on the same line)
> > configure: WARNING: you should use --build, --host, --target
> > checking build system type... Invalid configuration `...': machine
> > `...' not recognized
> > configure: error: /bin/bash ./config.sub ... failed
> > I've removed the third command and removed "..." from the last one.
> > But it still didn't work
> > Chris
> > On Mon, May 16, 2011 at 11:06 AM, sigfrido at tiscali.it
> > <sigfrido at tiscali.it>wrote:
> > > Hi Chris,
> > > I too have Ubuntu 10.04, and the CONFIGURE_SHELL solution
> > > worked for me. I didn't try the other solution, though.
> > > Sig
> > > Messaggio originale----
> > > Da: goocreations at gmail.com
> > > Data: 16/05/2011
> > > 10.53
> > > A: "sigfrido at tiscali.it"<sigfrido at tiscali.it>
> > > Cc: <Josh.
> > > Vote at csiro.au>, <gdal-dev at lists.osgeo.org>
> > > Ogg: Re: RE: [gdal-dev] GDAL
> > > Hi
> > > I still have the problem
> > > Ubuntun 10.04.
> > > I've tried the above solutions without any sucess.
> > > Any
> > > Ubuntu users have a solution?
> > > Chris
> > > On Mon, May 16, 2011 at 10:28 AM,
> > > > Hi all,
> > > > also
> > > setting the CONFIGURE_SHELL variable before running
> > > > configure worked
> > > for me:
> > > > export
> > > > CONFIGURE_SHELL
> > > Non temiamo alcun confronto: Tiscali ha l'Adsl più veloce d'Italia!
> > > Risparmia con Tutto Incluso Light: Voce + Adsl 20 mega a soli 17,95
> > > € al mese per 12 mesi.
> http://abbonati.tiscali.it/telefono-adsl/prodotti/tc/tuttoincluso_light/?WT.mc_id=01fw
> Antonio Valentino
> gdal-dev mailing list
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110516/ed83b3a6/attachment.html
