[gdal-dev] why some projection info can not read by ArcGIS9.3
atubar
atubar at 126.com
Thu May 26 01:09:04 EDT 2011
Hi, everybody. I create a new tiff , just named it A, from another tiff (named B ), and set the projection by wkt which is read from the B.
But prejection of A cann't be read by arcgis 9.3, and B can . what about the problem is?
The projection info is like this :
PROJCS["IMAGINE GeoTIFF Support
Copyright 1991 - 2005 by Leica Geosystems Geospatial Imaging, LLC. All Rights Reserved
@(#)$RCSfile: egtf.c $ IMAGINE 9.0 $Revision: 10.0 $ $Date: 2005/07/26 15:10:00 EST $
Projection = Albers Conical Equal Area",GEOGCS["Krasovsky",DATUM["Krasovsky",SPHEROID["Krasovsky",6378245,298.300017117214]],PRIMEM["Greenwich",0],UNIT["degree",0.0174532925199433]],PROJECTION["Albers_Conic_Equal_Area"],PARAMETER["standard_parallel_1",25],PARAMETER["standard_parallel_2",47],PARAMETER["latitude_of_center",0],PARAMETER["longitude_of_center",105],PARAMETER["false_easting",0],PARAMETER["false_northing",0],UNIT["metre",1,AUTHORITY["EPSG","9001"]]]
BTW, how those files compile out in folder ..\data\ such as coordinate_axis.csv, gcs.csv in use ?
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110526/4ae02277/attachment.html
