[gdal-dev] OGRinfo works, but a MapServer test mode=map DOES NOT
Eduardo Kanegae
eduardo.kanegae at gmail.com
Thu May 26 06:26:34 EDT 2011
Hi all,
I´m running Windows Server 2008 R2 Enterprise SP1 64bits using MS4W
3.0.1 with MapServer CGI 5.6.6 grabed from MapTools.org
My spatial data is on SQL Server 2008 + MsSqlSpatial 0.1.1 Lib and
I´ve set an ODBC DSN connection using SQL Server Native Driver 10
( using Control Panel -> ODBC Admin -> System DSN and also
C:\Windows\SysWOW64\odbcad32.exe tool )
When I run ogrinfo using:
$ ogrinfo -so "MSSQL:dsn=my_dsn;server=(local);database=my_database;tables=dbo.my_table;uid=my_user;pwd=my_passwd"
my_table
it works and dumps info like:
INFO: Open of `MSSQL:dsn=nucoffee;server=(local);database=nucoffee;tables=dbo.fazendas2;uid=db_nucoffee;pwd=@&NuCoFfEe&@'
using driver `MSSQLSpatial' successful.
... and so on!
BUT, when trying a MapServer CGI mode map request like:
http://my_server/cgi-bin/mapserv.exe?map=e:/my_mapfile.map&mode=map&layers=all&map_size=800+600
I only got the error:
msDrawMap(): Image handling error. Failed to draw layer named
'pol_my_layer'. msOGRFileOpen(): OGR error. Open failed for OGR
connection in layer `pol_my_layer'. Unable to initialize ODBC
connection to DSN for my_user/my_passwd at my_dsn, [Microsoft][ODBC
Driver Manager] Data source name not found and no default driver
specified
Can anybody give me a clue on that?
My LAYER mapfile part is defined as :
LAYER
NAME "pol_my_layer"
TYPE POLYGON
CONNECTIONTYPE OGR
CONNECTION "<OGRVRTDataSource>
<OGRVRTLayer name='pol_my_layer'>
<SrcDataSource>ODBC:my_user/my_passwd at my_dsn</SrcDataSource>
<SrcLayer>dbo.vw_pol_my_spatial_view</SrcLayer>
<LayerSRS>WGS84</LayerSRS>
<GeometryType>wkbUnknown</GeometryType>
<GeometryField encoding='WKB' field='geom_2005'/>
</OGRVRTLayer>
</OGRVRTDataSource>"
DATA "pol_my_layer"
FILTER "329"
FILTERITEM "farm_id"
PROCESSING "CLOSE_CONNECTION=DEFER"
END
END
best regards,
Eduardo Patto Kanegae
