[gdal-dev] Re: [mapserver-users] OGRinfo works,
but a MapServer test mode=map DOES NOT
Brent Fraser
bfraser at geoanalytic.com
Thu May 26 10:14:10 EDT 2011
Eduardo,
What happens when you use ogrinfo to access it via ODBC:
ogrinfo ODBC:my_user/my_passwd at my_dsn
or if you put the connection in a vrt file and use ogrinfo on it?
Best Regards,
Brent Fraser
On 5/26/2011 4:26 AM, Eduardo Kanegae wrote:
> Hi all,
> I´m running Windows Server 2008 R2 Enterprise SP1 64bits using MS4W
> 3.0.1 with MapServer CGI 5.6.6 grabed from MapTools.org
> My spatial data is on SQL Server 2008 + MsSqlSpatial 0.1.1 Lib and
> I´ve set an ODBC DSN connection using SQL Server Native Driver 10
> ( using Control Panel -> ODBC Admin -> System DSN and also
> C:\Windows\SysWOW64\odbcad32.exe tool )
> When I run ogrinfo using:
> $ ogrinfo -so "MSSQL:dsn=my_dsn;server=(local);database=my_database;tables=dbo.my_table;uid=my_user;pwd=my_passwd"
> my_table
> it works and dumps info like:
> INFO: Open of `MSSQL:dsn=nucoffee;server=(local);database=nucoffee;tables=dbo.fazendas2;uid=db_nucoffee;pwd=@&NuCoFfEe&@'
> using driver `MSSQLSpatial' successful.
> ... and so on!
> BUT, when trying a MapServer CGI mode map request like:
> http://my_server/cgi-bin/mapserv.exe?map=e:/my_mapfile.map&mode=map&layers=all&map_size=800+600
> I only got the error:
> msDrawMap(): Image handling error. Failed to draw layer named
> 'pol_my_layer'. msOGRFileOpen(): OGR error. Open failed for OGR
> connection in layer `pol_my_layer'. Unable to initialize ODBC
> connection to DSN for my_user/my_passwd at my_dsn, [Microsoft][ODBC
> Driver Manager] Data source name not found and no default driver
> specified
> Can anybody give me a clue on that?
> My LAYER mapfile part is defined as :
> LAYER
> NAME "pol_my_layer"
> TYPE POLYGON
> CONNECTIONTYPE OGR
> CONNECTION "<OGRVRTDataSource>
> <OGRVRTLayer name='pol_my_layer'>
> <SrcDataSource>ODBC:my_user/my_passwd at my_dsn</SrcDataSource>
> <SrcLayer>dbo.vw_pol_my_spatial_view</SrcLayer>
> <LayerSRS>WGS84</LayerSRS>
> <GeometryType>wkbUnknown</GeometryType>
> <GeometryField encoding='WKB' field='geom_2005'/>
> </OGRVRTLayer>
> </OGRVRTDataSource>"
> DATA "pol_my_layer"
> FILTER "329"
> FILTERITEM "farm_id"
> PROCESSING "CLOSE_CONNECTION=DEFER"
> END
> END
> best regards,
> Eduardo Patto Kanegae
> mapserver-users at lists.osgeo.org
