[gdal-dev] Problems writing big tiff image with RasterIO function
Jorge Martin jormarfe at gmail.com
Wed Nov 2 03:54:54 EDT 2011
 Hello,
      I am using an old version of the gdal library: 1.4.4.
      I have include below the code I used to write the tiff image:
    WriteImage(string aPath, int *myBuffer, int myNumLines, int myNumCols)
    GDALRegister_GTiff();
    GDALDataset  *m_poDataset;
    const char *pszFormat = "GTiff";
    GDALDriver *poDriver;
    poDriver = GetGDALDriverManager()->GetDriverByName(pszFormat);
    if( poDriver == NULL ) return ( 0 );
    char **papszOptions = NULL;
    m_poDataset = poDriver->Create( aPath.c_str(), myNumColumns,
myNumLines,  1, GDT_Byte,
                                                    papszOptions );
    GDALRasterBand  *poBand = m_poDataset->GetRasterBand(1);
     poBand->RasterIO( GF_Write, 0, 0, myNumColumns, myNumLines,
                      myBuffer, myNumColumns, myNumLines, GDT_Int32, 0, 0 );
    GDALClose(m_poDataset);
    return 1;
Best Regards,
Jorge
2011/10/31 Brian Claywell <bcclaywell at gmail.com>
> Jorge,
> On Mon, Oct 31, 2011 at 2:17 PM, Even Rouault
> <even.rouault at mines-paris.org> wrote:
> > Selon Jorge Martin <jormarfe at gmail.com>:
> >>        I am using RasterIO function to write tiff files. The problem
> >> appears when the image size is aprox. 25000x25000 (500Mb), the last
> lines
> >> of the image are not correctly written. The last lines are written with
> 0
> >> or 255 value. I have checked that if I only write a tiff file with the
> last
> >> lines of the image, this lines are correctly written.
> <snip>
> > You didn't mention your GDAL version. If it is not a recent one, you
> could try
> > upgrading and see if it works better.
> If you're seeing this behavior pre-1.8.1, it sounds similar to this
> bug, which has since been fixed:
> http://trac.osgeo.org/gdal/ticket/4090
> -b
> Brian Claywell
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20111102/493731b2/attachment.html
