[gdal-dev] Problems writing big tiff image with RasterIO function
Even Rouault even.rouault at mines-paris.org
Wed Nov 2 04:53:39 EDT 2011
Selon Jorge Martin <jormarfe at gmail.com>:
>  Hello,
>       I am using an old version of the gdal library: 1.4.4.
>       I have include below the code I used to write the tiff image:
Your code looks OK (provided that the values in your buffer are also OK), so I'd
suspect indeed it is a bug in 1.4.4 that hopefully is fixed by more recent
versions. The latest stable version is 1.8.1
