[gdal-dev] Problems writing big tiff image with RasterIO function
Jorge
jormarfe at gmail.com
Wed Nov 2 05:28:21 EDT 2011
Ok, thank you very much!
I have written a little image with only the last lines of the original image and this image does not have the strange values, so the problem should be the bug you have mentioned.
Best regards,
Jorge
El 02/11/2011, a las 09:53, Even Rouault <even.rouault at mines-paris.org> escribió:
> Selon Jorge Martin <jormarfe at gmail.com>:
>> Hello,
>> I am using an old version of the gdal library: 1.4.4.
>> I have include below the code I used to write the tiff image:
> Your code looks OK (provided that the values in your buffer are also OK), so I'd
> suspect indeed it is a bug in 1.4.4 that hopefully is fixed by more recent
> versions. The latest stable version is 1.8.1
