[gdal-dev] VSIF and Python
Frank Broniewski brfr at metrico.lu
Mon Nov 14 07:44:42 EST 2011
I wanted to try the VSIF* functions that are mentioned in the docs [1].
I am using gdal (and python-gdal) from debian testing, which is version
1.7.?. The VSIF* functions are "not found", so I presume they are
available with gdal >= 1.8 only?
I found [2], which is pretty much what I want to do: read geodata with
ogr, do some work with it and dump the result, in case of a text file
format, to string instead to file. Right now I am doing the same with an
extra step (save the result to file and read it again with python).
There's no way to inject a file like object (file, stringio) to gdal
instead of path names, isn't there?
Thanks
Frank
[1] http://gdal.org/python/
[2]
http://osgeo-org.1803224.n2.nabble.com/gdal-dev-NET-and-OGR-writing-to-stream-td6638444.html#a6648549
Frank BRONIEWSKI
METRICO s.à r.l.
géomètres
technologies d'information géographique
rue des Romains 36
L-5433 NIEDERDONVEN
tél.: +352 26 74 94 - 28
fax.: +352 26 74 94 99
http://www.metrico.lu
