[gdal-dev] VSIF and Python
Etienne Tourigny
etourigny.dev at gmail.com
Mon Nov 14 09:39:22 EST 2011
Yes, VSI* has been implemented in gdal 1.8.0, you should use the
latest stable 1.8.1.
You have this in debian experimental, but I don't use debian so can't
comment on how "experimental" the debian gdal 1.8 builds are.
You can also build gdal yourself from source.
Provided you upgrade to 1.8.1, you should be able to reproduce [2]
using the vsimem interface.
Etienne
On Mon, Nov 14, 2011 at 10:44 AM, Frank Broniewski <brfr at metrico.lu> wrote:
> Hi,
> I wanted to try the VSIF* functions that are mentioned in the docs [1]. I am
> using gdal (and python-gdal) from debian testing, which is version 1.7.?.
> The VSIF* functions are "not found", so I presume they are available with
> gdal >= 1.8 only?
> I found [2], which is pretty much what I want to do: read geodata with ogr,
> do some work with it and dump the result, in case of a text file format, to
> string instead to file. Right now I am doing the same with an extra step
> (save the result to file and read it again with python).
> There's no way to inject a file like object (file, stringio) to gdal instead
> of path names, isn't there?
> Thanks
> Frank
> [1] http://gdal.org/python/
> [2]
> http://osgeo-org.1803224.n2.nabble.com/gdal-dev-NET-and-OGR-writing-to-stream-td6638444.html#a6648549
> Frank BRONIEWSKI
> METRICO s.à r.l.
> géomètres
> technologies d'information géographique
> rue des Romains 36
> L-5433 NIEDERDONVEN
> tél.: +352 26 74 94 - 28
> fax.: +352 26 74 94 99
> http://www.metrico.lu
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
