[gdal-dev] ogr2ogr reprojection, features are not transformed
Even Rouault
even.rouault at mines-paris.org
Tue Nov 15 17:36:52 EST 2011
Etienne,
> I am working with data in the SAD69 Datum (EPSG:4618) from Brazil's
> IBGE and when I convert any data to/from WGS84 (EPSG:4362) it appears
> that there is absolutely no shift in the coordinates.
4326 you meant ?
> I understand that they are similar datums, but one would expect a visible
> shift. The only changes are in the files are the .prj file which contain
> the SAD69 or WGS84 GEOGCS.
> I use the following command:
> $ ogr2ogr --debug on -t_srs EPSG:4326 LC_CIDADE_wgs84.shp LC_CIDADE.shp
> OGR: OGROpen(LC_CIDADE.shp/0x1384170) succeeded as ESRI Shapefile.
> OGRCT: Source: +proj=longlat +ellps=aust_SA +no_defs
> OGRCT: Target: +proj=longlat +datum=WGS84 +no_defs
> Shape: DBF Codepage = LDID/87 for LC_CIDADE_wgs84
> Shape: Treating as encoding 'ISO-8859-1'.
> Shape: 5806 features read on layer 'LC_CIDADE'.
The issue is that the .prj format (ESRI WKT) doesn't store the TOWGS84
parameters. So you have to manually specify the source SRS so that GDAL can
fetch it from the EPSG database.
Try :
ogr2ogr --debug on -s_srs EPSG:4618 -t_srs EPSG:4326 LC_CIDADE_wgs84.shp
LC_CIDADE.shp
Perhaps the shapefile driver could call AutoIdentifyEPSG() to fill the part
losts in .prj format, but it wouldn't help for your case, because just a few
SRS are autodetected currently.
Best regards,
Even
