[gdal-dev] esri hdr format header
francesco
francesco.pirotti at unipd.it
Wed Nov 23 08:00:31 EST 2011
Hello,
I looked all day for information regarding the following problem, but
found none, so maybe the list can give me a hand:
When using GDAL C API reading and writing ESRI hdr files (floating point
binaries), the output header is very different from the header of the
input file (see examples below).
From GDAL documentation ESRI files should be written using the first
header example. Am I missing some very obvious thing here? -Problem is
that some GIS programs do not recognize the header in output from GDAL.
Thank you for you time!
Cheers,
Francesco Pirotti
Header in INPUT:
ncols 2000
nrows 2000
xllcorner 424000
yllcorner 4550000
cellsize 1
NODATA_value -9999
byteorder LSBFIRST
NODATA -9999
Header in OUTPUT:
BYTEORDER I
LAYOUT BIL
NROWS 2000
NCOLS 2000
NBANDS 1
NBITS 32
BANDROWBYTES 8000
TOTALROWBYTES 8000
PIXELTYPE FLOAT
ULXMAP 424000.5
ULYMAP 4551999.5
XDIM 1
YDIM 1
NODATA -9999
*Francesco Pirotti*
Dep. TESAF
CIRGEO -- Interdepartmental Research Center on Cartography Photogrammetry
Remote Sensing and G.I.S.
University of Padova
Web: http://www.cirgeo.unipd.it/cirgeo/francescopirotti.htm
Email: francesco.pirotti at unipd.it <mailto:francesco.pirotti at unipd.it>
Work Phone: +39 049 827 2710
Work Cell.: +39 392 395 2067
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20111123/e5e64662/attachment.html
