[gdal-dev] ogr.Feature field access
Ari Jolma
ari.jolma at gmail.com
Wed Nov 23 13:33:12 EST 2011
On 11/23/2011 08:53 AM, Frank Warmerdam wrote:
> Folks,
> Tonight I have made some changes to the OGR Python bindings such that
> there is a SetField2() method that tries to support a wider variety of
> value types that can be assigned to a field, including the list types.
> I also implemented __setattr__, __getitem__ and __setitem__ so that you
> can do things like:
> feat.area = 123
> feat['area'] = 123
> print feat['area']
> Note that __getattr__ was already implemented so you could already use
> feat.area if there was a field called 'area'.
> I did the new accessors mostly so that I can have them call SetField2()
> and take advantage of the new value semantics in a clean way. With this
> is it now possible to do something like:
> feat.my_list_field = [1,2,3]
> assuming 'my_list_field' is a field of type ogr.OFTInteger.
Interesting. This kind of access to various types of attributes has been
in Perl bindings (SetField/GetField or simply Field methods) a long
time. I just added the support for FETCH and STORE, i.e.,
$feature->{field} syntax - which is not as pretty as Python's but is
useful in some cases.
Ari
> I have also added a new test file (autotest/ogr/ogr_feature.py) that
> checks
> how different types of field values are assigned by SetFrom(). This is
> preliminary to my trying to improve how the C++ OGRFeature::SetFrom()
> method
> assigns between different field types. I want to improve it so that some
> obvious things are possible. For instance assigning an integer to an
> integer list should create a one length list.
> This work will likely take me a while. Even - I know you could leap out
> and finish that work before wake up, but I'd appreciate it if you
> could give
> me a couple weeks to do it at my pace. :-)
> Feedback on whether the Python changes are causing problems or are
> expected
> to are welcome. They are:
> http://trac.osgeo.org/gdal/changeset/23416
> http://trac.osgeo.org/gdal/changeset/23417
> Best regards,
