[gdal-dev] Resquest for comments (RFC 36)
Chaitanya kumar CH
chaitanya.ch at gmail.com
Mon Oct 3 23:55:27 EDT 2011
What happens when a user tries to open a file named "hfa:example_file.img"
the current way when there is also a file name "example_file.img"?
What if we try to reorder the driver list according to the file extension?
On Tue, Oct 4, 2011 at 8:22 AM, Daniel Morissette
<dmorissette at mapgears.com>wrote:
> On 11-10-03 10:04 PM, Frank Warmerdam wrote:
>> I believe that is because it is hard to know if HFA:test.tif was really
>> something other than a request for the HFA driver. It could actually
>> be a file named "HFA:test.tif" or it could be that another driver happens
>> to use the HFA: prefix to mean something. I believe this is an
>> effort to avoid failure in these cases.
> Um... the best I can say then is -0 in the hope that we can find a better
> delimiter or syntax. Unfortunately I just can't come up with a better option
> at the moment.
>> I'm not convinced that this is necessary. I have had a hope for
>> some time to provide a standard way of binding up open options,
>> including the driver name, for OGR as demonstrated by a
>> request like:
>> @driver=ingres,dbname=test
> Unfortunately "@driver=ingres,dbname=test.**tif" is also a valid filename,
> so we'd have the same problem as with "HFA:test.tif" above.
> I also think it is important to be consistent between GDAL and OGR for
> something like this.
> Once again, I'm not trying to kill the idea, just pointing the flaws in the
> hope that the someone in the group will find a more predictable mechanism.
> Daniel Morissette
> http://www.mapgears.com/
> Provider of Professional MapServer Support since 2000
> ______________________________**_________________
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> http://lists.osgeo.org/**mailman/listinfo/gdal-dev<http://lists.osgeo.org/mailman/listinfo/gdal-dev>
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20111004/c9a7791c/attachment.html
