Re: [gdal-dev] Resquest for comments (RFC 36)
Ivan Lucena
ivan.lucena at pmldnet.com
Tue Oct 4 22:45:30 EDT 2011
Frank,
Sorry for the confusion. Please disregard my last message. I didn't had the time to edit it properly.
But I am happy to see that the discussion has brought some interesting ideas and some important concerns.
That is what I think we should do:
- Keep backward compatibility. Simple files names and drivers specific entries should works as usual;
- The initial approach, "drivername:" is misleading and problematic;
- We should use an unambiguous token to express exactly that a driver has been chosen.
In my option the "driver=" is the best approach because:
- It is simple enough to be used in command line, if needed (what is rarely the case);
- It works well with entries like "table=" or "user=";
- It doesn't create problems with driver that consume prefixes that are not real drivers names.
> The "@" prefix is the clue to kick into the special logic. We would
> likely want to avoid it if the file "@driver=gtiff,landsat1.tif" actually
> existed in the filesystem.
Please note in the proposed code that If the file exist ("oOpenInfo.bStatOK == false") there is no need to check for anything else. Existing file will always be handle by the driver probing. IMHO I would rather not have the "@". The possibility of having a file by the name of "driver=something" is basically the same as "@driver=something".
Except by the "@", I agree with what you and Even discussed as a proposed format:
> @[driver=drivername,]option1=value1,options2=value2,filename
I would guess that the list of "option=value" and "filename" would be parsed by GDALOpenInfo constructor, like in:
GDALOpenInfo oOpenInfoClone( "option1=value1,options2=value2,filename", eAccess );
That should work well in either strategy, driver probing or open-by-drivername. I think.
My best regards,
Ivan
> -------Original Message-------
> From: Frank Warmerdam <warmerdam at pobox.com>
> To: Even Rouault <even.rouault at mines-paris.org>
> Cc: gdal-dev at lists.osgeo.org, Ivan Lucena <ivan.lucena at pmldnet.com>
> Subject: Re: [gdal-dev] Resquest for comments (RFC 36)
> Sent: Oct 04 '11 13:52
> On Tue, Oct 4, 2011 at 11:42 AM, Even Rouault
> <even.rouault at mines-paris.org> wrote:
> > That's exactly my understanding of what the latest patch
> > http://trac.osgeo.org/gdal/attachment/ticket/3043/open_by_drivername_v3.patch
> > does.
> Even,
> Good, but I didn't understand what Ivan was suggesting/proposing.
> >> The main advantage of the @ approach is that it is intended to be
> >> easier to specify multiple open options.
> > Even if it is not in the scope of current RFC, do you have an idea of what the
> > syntax would be for open options so as we can pick up something that could be
> > later extended ?
> > Something like :
> > @[driver=drivername,]option1=value1,options2=value2,filename ?
> This was my rough intention with, hopefully, well defined quoting or
> escaping rules to take into account the case where the regular filename
> contains commas. One of the thing that held me back from pushing
> this was coming up with good rules on quoting/escaping. The use of
> quotes in subdataset names in stuff like the HDF driver is a great headache.
> In the gdalinfo report on a HDF driver we try to report the subdataset names
> with clear quoting, but if folks cut and paste that into a shell the quotes
> get eaten by the shell which makes it very hard for users to know what
> they need to do unless they are quite shell-savvy. I'd like to avoid that
> if possible.
> >> Particularly on the OGR side
> >> there has long been a desire to control how some DB opens are done
> >> with extra open options but now the only way we can provide these is
> >> via config options.
> > Actually on OGR side, apart from the configuration options, you also have the
> > notion of connection strings, like for the PG driver, to provide the driver
> > name, database name, host, port, etc etc...
> Yes, my intention was to regularize how connection strings are done.
> So if applied to the postgres driver we would have stuff like:
> @driver=pg,host=localhost,password=tiger,dbname=ottawa
> What I don't like now is that the connection string parsing,
> quoting, etc is handled differently in the different DB drivers.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Software Developer
