[gdal-dev] sandbox access for non-commiters
Etienne Tourigny
etourigny.dev at gmail.com
Thu Oct 6 15:26:38 EDT 2011
My main concern with using github is that the bridge between svn and
git may or may not be easy to learn. I tried the procedure you
describe in the wiki and it was painfully slow on import. I didn't
know that you kept it up to date, because last time I checked it was
out of date.
Is it possible as a commiter to use a single local git repository that
can be used for both the official svn (for commits) and also in github
(to interact with other contributors)?
>From your instructions it looks doable, but can you push and pull to
the github repos, and then commit changes back to gdal svn?
If that's easy then I would definitely use that approach instead of svn sandbox.
regards,
Etienne
On Thu, Oct 6, 2011 at 3:16 PM, Mateusz Loskot <mateusz at loskot.net> wrote:
> On 06/10/11 19:07, Frank Warmerdam wrote:
>> On Wed, Oct 5, 2011 at 11:50 PM, Antonio Valentino
>> <antonio.valentino at tiscali.it> wrote:
>>> Anyway I think that the possibility of maintaining an official mirror
>>> of GDAL on a Git or Mercurial repository should be considered and
>>> contributors should be encouraged to use it.
>>> Here it is an unofficial mirror
>>> https://github.com/mloskot/gdal
>>> and a wiki page about the topic on the GDAL trac
>>> http://trac.osgeo.org/gdal/wiki/UsingGitToMaintainGDALWorkflow
>> Antonio,
>> If it was to be made "official" it would need an RFC. I'm
>> not sure what the benefit of making it official is. I will
>> note that I am rabidly anti-git for GDAL but I will as always
>> bow to the will of the PSC and duely passed RFCs.
> Frank / Antonio,
> FYI, I keep the repo at https://github.com/mloskot/gdal up to
> date daily. I'm assembling a server at home, so it will become
> cronjob-managed soon.
> I am not proposing git for GDAL.
> However, I believe github could be very useful to host GDAL sandbox
> which can be forked by anyone and without hassle of managing privs
> in OSGeo SVN.
> Best regards,
> Mateusz Loskot, http://mateusz.loskot.net
> Charter Member of OSGeo, http://osgeo.org
> Member of ACCU, http://accu.org
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
