[gdal-dev] ogr2ogr: cartesian geographic coordinates problem
Luca Sigfrido Percich
sigfrido at tiscali.it
Tue Oct 11 03:50:13 EDT 2011
Hi Max,
have you tried
ogr2ogr -t_srs EPSG:4326 -f "one of many formats" outputfile myshape.shp
As ogrinfo recognizes the source shape CS (I guess it has a .prj file
associated with it), you should only transform (-t_srs) into the
destination CS.
All the best
Sig
Il giorno lun, 10/10/2011 alle 11.14 +0200, emmexx ha scritto:
> I'm new to this list, sorry if my question is not new or OT.
> I was given a shape file containing linestrings based on a CTR map (CTR
> is a "technical italian map").
> The file uses Roma1940 and the coordinates are geographic. This is the
> start of the output of ogrinfo -al:
> Geometry: Line String
> Feature Count: 185
> Extent: (9.048641, 45.413654) - (9.267740, 45.527227)
> Layer SRS WKT:
> GEOGCS["GCS_Roma_1940",
> DATUM["Roma_1940",
> SPHEROID["International_1924",6378388,297]],
> PRIMEM["Greenwich",0],
> UNIT["Degree",0.017453292519943295]]
> I need to convert the shape file to EPSG:4326 to view the data on google
> or osm maps.
> I received, and found also on the web, some srs to make the conversion
> from Gauss-Boaga to wgs84 but, if I understand correctly, all those
> files expect the coordinates of the points to be cartesian, not geographic.
> I tried to use ogr2ogr with the following parameters:
> ogr2ogr -a_srs "gausboaga.prj" -s_srs "latlong_wgs84.prj" -t_srs
> "EPSG:4326" -f "one of many formats" outputfile myshape.shp
> (the srs files at the end of the message)
> What I get are points with geographic coordinates changed at the
> 13th-14th decimal place. E.g.:
> 9.170837078374765,45.525406361655726
> becomes
> 9.170837078374774,45.525406361655769
> As a test I downloaded a shape file of my city roads from a regional web
> service, the coordinates are cartesian, then I used a web tool to
> convert that shape file from epsg:3003 to epsg:4326 and the result is a
> file with lines that perfectly match gmaps or osm roads.
> If I try to use the same service with my shape file I get an error.
> I found out some formulas to derive cartesian from geographic
> coordinates for a transverse mercator projection
> (http://www.remotesensing.org/geotiff/proj_list/guid7.html) but I wonder
> if there is some ogr2ogr parameter or some srs to do the same.
> Thank you
> maxx
> "gausboaga.prj"
> PROJCS["Monte Mario / Italy zone 1",
> GEOGCS["Monte Mario",
> DATUM["Monte_Mario",
> SPHEROID["International 1924", 6378388.0, 297.0,
> AUTHORITY["EPSG","7022"]],
> TOWGS84[-104.1,-49.1,-9.9,0.971,-2.917,0.714,-11.68],
> AUTHORITY["EPSG","6265"]],
> PRIMEM["Greenwich", 0.0,
> AUTHORITY["EPSG","8901"]],
> UNIT["degree", 0.017453292519943295],
> AXIS["Lon", EAST],
> AXIS["Lat", NORTH],
> AUTHORITY["EPSG","4265"]],
> PROJECTION["Transverse_Mercator"],
> PARAMETER["central_meridian", 9.0],
> PARAMETER["latitude_of_origin", 0.0],
> PARAMETER["scale_factor", 0.9996],
> PARAMETER["false_easting", 1500000.0],
> PARAMETER["false_northing", 0.0],
> UNIT["m", 1.0],
> AXIS["x", EAST],
> AXIS["y", NORTH],
> AUTHORITY["EPSG","3003"]]
> "latlon_wgs84.prj"
> GEOGCS["wgs84",DATUM["WGS_1984",
> SPHEROID["wgs84",6378137,298.257223563],
> TOWGS84[0.000000,0.000000,0.000000]],
> UNIT["degree",0.0174532925199433]]
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
_____________
PRIVACY
Le informazioni contenute in questo messaggio sono riservate e confidenziali. Il loro utilizzo e' consentito esclusivamente al destinatario del messaggio, per le finalità indicate nel messaggio stesso. Qualora Lei non fosse la persona a cui il presente messaggio è destinato, La invitiamo ad eliminarlo dal Suo Sistema e a distruggere le varie copie o stampe, dandone gentilmente comunicazione all’indirizzo mail del mittente. Ogni utilizzo improprio e' contrario ai principi del D.lgs 196/03 e alla legislazione europea (Direttiva 2002/58/CE).
PRIVACY
