[gdal-dev] gdal_contour stuck in processing?
Chaitanya kumar CH
chaitanya.ch at gmail.com
Thu Oct 13 01:03:08 EDT 2011
Graeme,
Can you try again with a much larger interval?
On Thu, Oct 13, 2011 at 6:32 AM, Graeme Merrall <graeme at inetix.com.au>wrote:
> I'm trying out gdal_contour just to see what falls out of it as an
> experiment. I've noticed it seems to get to "0.." e.g. 7% or so, and
> then seems to hang. I'm trying it on a relatively small DTM
> The cmdline is pretty simple "gdal_contour -a ELEL -i 1.0
> dtm_11072101.tif dtm-1m.shp"
> and gdalinfo gives the following info about the image
> Driver: GTiff/GeoTIFF
> Files: dtm_11072101.tif
> dtm_11072101.tfw
> Size is 1000, 2500
> Coordinate System is `'
> Origin = (488000.000000000000000,7198000.000000000000000)
> Pixel Size = (2.000000000000000,-2.000000000000000)
> Metadata:
> TIFFTAG_XRESOLUTION=200
> TIFFTAG_YRESOLUTION=200
> TIFFTAG_RESOLUTIONUNIT=3 (pixels/cm)
> Image Structure Metadata:
> INTERLEAVE=BAND
> Corner Coordinates:
> Upper Left ( 488000.000, 7198000.000)
> Lower Left ( 488000.000, 7193000.000)
> Upper Right ( 490000.000, 7198000.000)
> Lower Right ( 490000.000, 7193000.000)
> Center ( 489000.000, 7195500.000)
> Band 1 Block=1000x2 Type=UInt32, ColorInterp=Gray
> I admit I'm at a loss as to how to proceed/troubleshoot so any
> pointers gratefully received. I tried popping it through
> gdal_translate to add a projection but it seems to have the same issue
> Cheers,
> Graeme
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20111013/67f8a3c4/attachment.html
