[gdal-dev] gdal_contour stuck in processing?
Graeme Merrall
graeme at inetix.com.au
Sun Oct 23 22:58:20 EDT 2011
Apologies for the delay in replying.
I ran the same command with 10m spacing "gdal_contour -a ELEL -i 1.0
dtm.tif dtm-10m.shp" and the same issue occurred. I also ran the DTM
through gdal_translate to add projection info just in case. Note this is
gdal_1.8.1 running on Ubuntu Lucid not from deb's but a custom compile
The same symptoms occur, it gets to around 7% or so then hangs. Load goes
through the roof.
Ran it through strace and seems to get stuck in massive loop with calling
brk()
Cheers,
Graeme
On Thu, Oct 13, 2011 at 4:03 PM, Chaitanya kumar CH
<chaitanya.ch at gmail.com>wrote:
> Graeme,
> Can you try again with a much larger interval?
> On Thu, Oct 13, 2011 at 6:32 AM, Graeme Merrall <graeme at inetix.com.au>wrote:
>> I'm trying out gdal_contour just to see what falls out of it as an
>> experiment. I've noticed it seems to get to "0.." e.g. 7% or so, and
>> then seems to hang. I'm trying it on a relatively small DTM
>> The cmdline is pretty simple "gdal_contour -a ELEL -i 1.0
>> dtm_11072101.tif dtm-1m.shp"
>> and gdalinfo gives the following info about the image
>> Driver: GTiff/GeoTIFF
>> Files: dtm_11072101.tif
>> dtm_11072101.tfw
>> Size is 1000, 2500
>> Coordinate System is `'
>> Origin = (488000.000000000000000,7198000.000000000000000)
>> Pixel Size = (2.000000000000000,-2.000000000000000)
>> Metadata:
>> TIFFTAG_XRESOLUTION=200
>> TIFFTAG_YRESOLUTION=200
>> TIFFTAG_RESOLUTIONUNIT=3 (pixels/cm)
>> Image Structure Metadata:
>> INTERLEAVE=BAND
>> Corner Coordinates:
>> Upper Left ( 488000.000, 7198000.000)
>> Lower Left ( 488000.000, 7193000.000)
>> Upper Right ( 490000.000, 7198000.000)
>> Lower Right ( 490000.000, 7193000.000)
>> Center ( 489000.000, 7195500.000)
>> Band 1 Block=1000x2 Type=UInt32, ColorInterp=Gray
>> I admit I'm at a loss as to how to proceed/troubleshoot so any
>> pointers gratefully received. I tried popping it through
>> gdal_translate to add a projection but it seems to have the same issue
>> Cheers,
>> Graeme
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> Best regards,
> Chaitanya kumar CH.
> +91-9494447584
> 17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20111024/80807cd5/attachment.html
