[gdal-dev] New mloskot-github-gdal-20111018.7z
Mateusz Łoskot
mateusz at loskot.net
Fri Oct 21 05:46:10 EDT 2011
On 21 October 2011 07:54, Antonio Valentino
<antonio.valentino at tiscali.it> wrote:
> It seems that the svn2git [1] tool (based on git-svn) is able to import
> svn repositories with branches in a proper way.
> I never used it an I don't know if it allows to push changes back to
> svn.
> Anyway since Julien only needs to generate a patch, svn2git should be
> good for its purposes.
> [1] https://github.com/nirvdrum/svn2git
"(...) This is a one way sync, but allows you to use svn2git as a
mirroring tool for your SVN repositories."
Thanks! It looks it is what we need.
I will try to recreate the mirror using svn2git over the weekend.
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
Charter Member of OSGeo, http://osgeo.org
Member of ACCU, http://accu.org
