[gdal-dev] New mloskot-github-gdal-20111018.7z
Etienne Tourigny
etourigny.dev at gmail.com
Fri Oct 21 09:33:02 EDT 2011
>From this page it seems like it's quite easy using just "git svn", and
doesn't require an extra tool.
http://trac.parrot.org/parrot/wiki/git-svn-tutorial
Instructions there are:
git svn clone -s -r 40000:HEAD https://svn.parrot.org/parrot # choose
some recent-ish commit
-s is for --stdlayout which presumes the svn recommended layout for
tags, trunk, and branches.
-r is for the revision to start taking history from. If you want to
include all of the history, just leave that option off, but it will
take a very long time, and you really don't need all of it.
This should also work (adding -s to git svn init), although I didn't try
git svn init -s https://svn.osgeo.org/gdal/trunk/
2011/10/21 Mateusz Łoskot <mateusz at loskot.net>:
> On 21 October 2011 07:54, Antonio Valentino
> <antonio.valentino at tiscali.it> wrote:
>> It seems that the svn2git [1] tool (based on git-svn) is able to import
>> svn repositories with branches in a proper way.
>> I never used it an I don't know if it allows to push changes back to
>> svn.
>> Anyway since Julien only needs to generate a patch, svn2git should be
>> good for its purposes.
>> [1] https://github.com/nirvdrum/svn2git
> "(...) This is a one way sync, but allows you to use svn2git as a
> mirroring tool for your SVN repositories."
> Thanks! It looks it is what we need.
> I will try to recreate the mirror using svn2git over the weekend.
> Best regards,
> Mateusz Loskot, http://mateusz.loskot.net
> Charter Member of OSGeo, http://osgeo.org
> Member of ACCU, http://accu.org
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
