[gdal-dev] New mloskot-github-gdal-20111018.7z
Antonio Valentino
antonio.valentino at tiscali.it
Sun Oct 23 07:17:00 EDT 2011
Hi Mateusz, hi Julien, hi Etienne,
Il 23/10/2011 02:41, Mateusz Łoskot ha scritto:
> 2011/10/22 Mateusz Łoskot <mateusz at loskot.net>:
>> 2011/10/21 Mateusz Łoskot <mateusz at loskot.net>:
>>> On 21 October 2011 07:54, Antonio Valentino
>>> <antonio.valentino at tiscali.it> wrote:
>>>> It seems that the svn2git [1] tool (based on git-svn) is able to import
>>>> svn repositories with branches in a proper way.
>>>> I never used it an I don't know if it allows to push changes back to
>>>> svn.
>>>> Anyway since Julien only needs to generate a patch, svn2git should be
>>>> good for its purposes.
>>>> [1] https://github.com/nirvdrum/svn2git
>>> "(...) This is a one way sync, but allows you to use svn2git as a
>>> mirroring tool for your SVN repositories."
>>> Thanks! It looks it is what we need.
>>> I will try to recreate the mirror using svn2git over the weekend.
>> I've rebuilt GDAL mirror at GitHub using svn2git.
>> I hope it's in usable state.
>> I've also updated the Wiki with the process explanation:
>> http://trac.osgeo.org/gdal/wiki/UsingGitToMaintainGDALWorkflow#Gitrepositorysetupusingsvn2git
> Folks,
> It turns out the full SVN repo mirroring is not working well.
> The GDAL Git at GitHub has broken, so moved it to gdal-old.
> The svn2git pulls number of very ancient pre-SVN branches created
> during CVS times
> which are no longer vislble at http://svn.osgeo.org/gdal
> Then gives up with weird errors which I have no idea about neither
> time to investigate.
> ATM, GDAL mirror at GitHub is not functioning. I'll try to bring it back ASAP.
> Best regards,
Just pushed on https://github.com/avalentino/gdal a new mirror of
https://svn.osgeo.org/gdal generated with git-svn and the --stdlayout
option (as suggested by Etienne).
The tool seems to handle both svn branches and tags ad git branches in
the svn remote, so I manually created branches and tags on the git side
pointing to them.
I should be able to sync the master branch with git-svn rebase but I
have no idea, at the moment, on hos to sync branches.
I'm going to upload a bzipped version of the git svn clone on
https://github.com/avalentino/gdal/downloads
regards
Antonio Valentino
