[gdal-dev] Re: Gdal_translate, question from an amateur.
Brian Case
rush at winkey.org
Sun Oct 23 10:02:25 EDT 2011
joolek,
I noticed you used the word "strip". Are you trying to remove portions
of the image that are all black or white?
On Sun, 2011-10-23 at 03:01 -0700, joolek wrote:
> Basically - I have an imagery with RGB 0-255, but I would like to strip it to
> 1-254.
> So i want to get rid off two extremes (0 and 255) - is this possible?
> Thank you
> J
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Gdal-translate-question-from-an-amateur-tp6921127p6921730.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
