[gdal-dev] Re: Gdal_translate, question from an amateur.
Jay L. jzl5325 at psu.edu
Sun Oct 23 10:25:55 EDT 2011
Or are you trying to convert only some of the pixels to white?
On Sun, Oct 23, 2011 at 10:02 AM, Brian Case <rush at winkey.org> wrote:
> joolek,
> I noticed you used the word "strip". Are you trying to remove portions
> of the image that are all black or white?
> On Sun, 2011-10-23 at 03:01 -0700, joolek wrote:
> > Basically - I have an imagery with RGB 0-255, but I would like to strip
> it to
> > 1-254.
> > So i want to get rid off two extremes (0 and 255) - is this possible?
> > Thank you
> > J
> > View this message in context:
> http://osgeo-org.1803224.n2.nabble.com/Gdal-translate-question-from-an-amateur-tp6921127p6921730.html
> > Sent from the GDAL - Dev mailing list archive at Nabble.com.
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20111023/11d0d52d/attachment.html
