[gdal-dev] Re: Gdal_translate, question from an amateur.
joolek
joolek.o at gmail.com
Sun Oct 23 12:59:42 EDT 2011
Hi
I need to convert all the 255 255 255 into 254 254 254. Is this possible?
PS. Do appologize for lack of my language.
Thanks
J
On 23 Oct 2011, at 15:26, "Jay L. [via OSGeo.org]" <ml-node+s1803224n6922091h97 at n2.nabble.com> wrote:
> Or are you trying to convert only some of the pixels to white?
> On Sun, Oct 23, 2011 at 10:02 AM, Brian Case <[hidden email]> wrote:
> joolek,
> I noticed you used the word "strip". Are you trying to remove portions
> of the image that are all black or white?
> On Sun, 2011-10-23 at 03:01 -0700, joolek wrote:
> > Basically - I have an imagery with RGB 0-255, but I would like to strip it to
> > 1-254.
> > So i want to get rid off two extremes (0 and 255) - is this possible?
> > Thank you
> > J
> > View this message in context: http://osgeo-org.1803224.n2.nabble.com/Gdal-translate-question-from-an-amateur-tp6921127p6921730.html
> > Sent from the GDAL - Dev mailing list archive at Nabble.com.
> > gdal-dev mailing list
> > [hidden email]
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
> [hidden email]
> [hidden email]
> If you reply to this email, your message will be added to the discussion below:
> http://osgeo-org.1803224.n2.nabble.com/Gdal-translate-question-from-an-amateur-tp6921127p6922091.html
> To unsubscribe from Gdal_translate, question from an amateur., click here.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Gdal-translate-question-from-an-amateur-tp6921127p6922377.html
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20111023/712f0c55/attachment.html
