[gdal-dev] Re: Gdal_translate, question from an amateur.
joolek
joolek.o at gmail.com
Sun Oct 23 14:53:57 EDT 2011
Hmm... So what the following does :
gdal_translate -scale 0 254 0 255 <input> <output>
Thank you
J
23 Oct 2011, at 19:20, "Jay L. [via OSGeo.org]" <ml-node+s1803224n6922518h34 at n2.nabble.com> wrote:
> I do not believe that a GDAL command line tool to perform that function exists. The task is achievable using GDAL and Numpy masked arrays in python.
> Perhaps someone else knows of a GDAL tool to perform this functionality though.
> J
> On Sun, Oct 23, 2011 at 12:59 PM, joolek <[hidden email]> wrote:
> Hi
> I need to convert all the 255 255 255 into 254 254 254. Is this possible?
> PS. Do appologize for lack of my language.
> Thanks
> J
> On 23 Oct 2011, at 15:26, "Jay L. [via OSGeo.org]" <[hidden email]> wrote:
>> Or are you trying to convert only some of the pixels to white?
>> On Sun, Oct 23, 2011 at 10:02 AM, Brian Case <[hidden email]> wrote:
>> joolek,
>> I noticed you used the word "strip". Are you trying to remove portions
>> of the image that are all black or white?
>> On Sun, 2011-10-23 at 03:01 -0700, joolek wrote:
>> > Basically - I have an imagery with RGB 0-255, but I would like to strip it to
>> > 1-254.
>> > So i want to get rid off two extremes (0 and 255) - is this possible?
>> > Thank you
>> > J
>> > View this message in context: http://osgeo-org.1803224.n2.nabble.com/Gdal-translate-question-from-an-amateur-tp6921127p6921730.html
>> > Sent from the GDAL - Dev mailing list archive at Nabble.com.
>> > _______________________________________________
>> > gdal-dev mailing list
>> > [hidden email]
>> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
>> [hidden email]
>> [hidden email]
>> If you reply to this email, your message will be added to the discussion below:
>> http://osgeo-org.1803224.n2.nabble.com/Gdal-translate-question-from-an-amateur-tp6921127p6922091.html
>> To unsubscribe from Gdal_translate, question from an amateur., click here.
> View this message in context: Re: Gdal_translate, question from an amateur.
> [hidden email]
> [hidden email]
> http://osgeo-org.1803224.n2.nabble.com/Gdal-translate-question-from-an-amateur-tp6921127p6922518.html
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Gdal-translate-question-from-an-amateur-tp6921127p6922637.html
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20111023/f5622d3c/attachment-0001.html
