[gdal-dev] Re: Gdal_translate, question from an amateur.
Brian Case
rush at winkey.org
Sun Oct 23 17:19:52 EDT 2011
Joolek,
gdal_translate cannot look at 3 bands at a time, -scale 0 255 1 254 will
scale each band separately, therefore 0 255 0 would become 1 254 1.
At one point I thought perhaps you were trying to get rid of a border,
but now I don't think thats the issue.
Brian
On Sun, 2011-10-23 at 11:53 -0700, joolek wrote:
> Hmm... So what the following does :
> gdal_translate -scale 0 <a href="tel:254%200%20255">254 0 255 <input>
> <output>
> Thank you
> J
> 23 Oct 2011, at 19:20, "Jay L. [via OSGeo.org]" <[hidden email]>
> wrote:
> > I do not believe that a GDAL command line tool to perform that
> > function exists. The task is achievable using GDAL and Numpy masked
> > arrays in python.
> > Perhaps someone else knows of a GDAL tool to perform this
> > functionality though.
> > J
> > On Sun, Oct 23, 2011 at 12:59 PM, joolek <[hidden email]> wrote:
> > Hi
> > I need to convert all the 255 255 255 into 254 254 254. Is
> > this possible?
> > PS. Do appologize for lack of my language.
> > Thanks
> > J
> > On 23 Oct 2011, at 15:26, "Jay L. [via OSGeo.org]" <[hidden
> > email]> wrote:
> > > Or are you trying to convert only some of the pixels to
> > > white?
> > > On Sun, Oct 23, 2011 at 10:02 AM, Brian Case <[hidden
> > > email]> wrote:
> > > joolek,
> > > I noticed you used the word "strip". Are you
> > > trying to remove portions
> > > of the image that are all black or white?
> > > On Sun, 2011-10-23 at 03:01 -0700, joolek wrote:
> > > > Basically - I have an imagery with RGB 0-255,
> > > but I would like to strip it to
> > > > 1-254.
> > > > So i want to get rid off two extremes (0 and
> > > 255) - is this possible?
> > > > Thank you
> > > > J
> > > > View this message in context:
> > > http://osgeo-org.1803224.n2.nabble.com/Gdal-translate-question-from-an-amateur-tp6921127p6921730.html
> > > > Sent from the GDAL - Dev mailing list archive at
> > > Nabble.com.
> > > > _______________________________________________
> > > > gdal-dev mailing list
> > > > [hidden email]
> > > > http://lists.osgeo.org/mailman/listinfo/gdal-dev
> > > [hidden email]
> > > [hidden email]
> > > __________________________________________________________
> > > If you reply to this email, your message will be added to
> > > the discussion below:
> > > http://osgeo-org.1803224.n2.nabble.com/Gdal-translate-question-from-an-amateur-tp6921127p6922091.html
> > > To unsubscribe from Gdal_translate, question from an
> > > amateur., click here.
> > ____________________________________________________________
> > View this message in context: Re: Gdal_translate, question
> > from an amateur.
> > Sent from the GDAL - Dev mailing list archive at Nabble.com.
> > [hidden email]
> > [hidden email]
> > ____________________________________________________________________
> > If you reply to this email, your message will be added to the
> > discussion below:
> > http://osgeo-org.1803224.n2.nabble.com/Gdal-translate-question-from-an-amateur-tp6921127p6922518.html
> > To unsubscribe from Gdal_translate, question from an amateur., click
> > here.
> ______________________________________________________________________
> View this message in context: Re: Gdal_translate, question from an
> amateur.
> gdal-dev at lists.osgeo.org
