[gdal-dev] ogrinfo and PGeo Driver for .mdb file, on Ubuntu
Chris Green
chris.green at ibstv.co.uk
Tue Oct 25 03:20:02 EDT 2011
Hi Eli
Thanks for your suggestion. Despite pulling most of my hair out I still
can't get past the syntax error thrown by the PGeo driver, so I would
certainly be interested to follow the alternative approach. However I see
in the drv_mdb documentation that GDAL/OGR >=1.9.0 is required, yet I can't
find anything for Ubuntu later than 1.8 (from UbuntuGIS unstable). Do you
have 1.9 on your Ubuntu, if so could you tell me where I can find it?
Chris
Sent: 24 October 2011 19:32
To: Chris Green
Cc: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] ogrinfo and PGeo Driver for .mdb file, on Ubuntu
Chris,
There is also another route that may work for PGeo,
http://www.gdal.org/ogr/drv_mdb.html I recently built that on Ubuntu but
have not used it yet. It looks like you are close on the other route
though.
HTH, Eli
On Mon, Oct 24, 2011 at 5:35 AM, Chris Green <chris.green at ibstv.co.uk>
wrote:
Hi List
I'm hoping someone can help me make ogr work under Linux with the PGeo
driver, so I can read an ESRI Personal Database .mdb file into Mapserver. I
can see from old posts that the basic problem is that MDBTools is a bit
'flaky' and needs a DSN based connection rather than connecting direct to
the .mdb data.
I have been trying to follow the instructions in
http://www.gdal.org/ogr/drv_pgeo.html . Having installed unixODBC and
MDBTools, I configured the odbcinst.ini and odbc.ini files as suggested and
it seems that I have partial success because when I define my datasource in
odbc.ini like so:
[my_pgeo]
Description = Sample PGeo Database
Driver = Microsoft Access Driver (*.mdb)
Database = /var/www/vhosts/mydomain.com/httpdocs/data/test.mdb
then the command ogrinfo PGeo:my_pgeo results in the following:
INFO: Open of 'PGeo:my_pgeo' using driver 'PGeo' successful.
Error: syntax error at line:2 col:0
I can't figure out what or where this syntax error can be. I feel that I am
quite close to success but don't know how to move forward from here. Can
anyone point me in the right direction please?
Chris
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20111025/3a0508be/attachment.html
