[gdal-dev] Problem converting certain postgis tables to spatialite
Andreas Neumann
a.neumann at carto.net
Wed Sep 7 10:16:28 EDT 2011
I am converting several tables from Postgis to SpatiaLite using
ogr2ogr.
Here is my command:
ogr2ogr -append -lco LAUNDER=yes -lco SPATIAL_INDEX=yes -nln
av_grenzpunkte -f SQLite uster.sqlite PG:"dbname='mydb' host='myserver'
port='5432' user='username' password='pw' schemas=av_user
tables=grenzpunkte(the_geom)"
The problem is that about 50% of the tables convert fine, while the
other half ends with a segmentation fault. I don't see a pattern yet why
some convert fine, while others do not.
I am using Ubuntu 64bit, latest trunk and libspatialite 2.3.1
Do you have any idea how I can find out what the problem is with the
tables that do not convert? Any experiences with similar behavior and
how to solve it?
Thanks,
Andreas
Andreas Neumann
Böschacherstrasse 10A
8624 Grüt (Gossau ZH)
Switzerland
