[gdal-dev] Re: Python bindings: How to merge two geometries
vasile
vasile.cotovanu at webgis.ro
Wed Sep 7 13:36:54 EDT 2011
Frank Warmerdam wrote:
> The fix then is to clone it when you want it to live for a while.
> Also, I believe that the Union method returns the unioned
> geometry - it does not modify the geometry on which it is invoked.
That did the trick, it works just fine, thanks !
> Lastly, please try to avoid assuming feature id's are consecutive.
> So an improved script might look a bit like:
Acknowledged, it's much nicer now.
Thanks again,
Vasile
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Python-bindings-How-to-merge-two-geometries-tp6768614p6768777.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
