[gdal-dev] Re: Python bindings: How to merge two geometries
Even Rouault even.rouault at mines-paris.org
Wed Sep 7 14:43:21 EDT 2011
Le mercredi 07 septembre 2011 19:36:54, vasile a écrit :
> Frank Warmerdam wrote:
> > The fix then is to clone it when you want it to live for a while.
> > Also, I believe that the Union method returns the unioned
> > geometry - it does not modify the geometry on which it is invoked.
> That did the trick, it works just fine, thanks !
> > Lastly, please try to avoid assuming feature id's are consecutive.
> > So an improved script might look a bit like:
> Acknowledged, it's much nicer now.
You will find other tips&tricks related to life-time management in
http://trac.osgeo.org/gdal/wiki/PythonGotchas
You're welcome to expand it with your use case.
> Thanks again,
> Vasile
> http://osgeo-org.1803224.n2.nabble.com/Python-bindings-How-to-merge-two-ge
> ometries-tp6768614p6768777.html Sent from the GDAL - Dev mailing list
> archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
