[gdal-dev] Problems with building GDAL 1.9 on Windows with MS VC
2008 and OSGeo4W
Alexander Bruy
alexander.bruy at gmail.com
Sat Sep 24 09:43:57 EDT 2011
Thanks, renaming cpl_config.h.vc to cpl_config.h solves the problem.
Now GDAL compiles.
Unfortunatelly, I can't build Python bindigns because Python in OSGeo4W
was built with VS 2003 and seems there are no downloads for this VC version.
Bad...
2011/9/24 Even Rouault <even.rouault at mines-paris.org>:
> Le samedi 24 septembre 2011 14:01:35, Alexander Bruy a écrit :
> The line numbers in the error message makes me believe that, for some reason,
> the cpl_config.h that gets used is the Unix one and not the one coming from
> cpl_config.h.vc. So I'd suggest you delete port/cpl_config.h and start building
> again.
Thanks
Alexander Bruy
