[gdal-dev] Problems with building GDAL 1.9 on Windows with MS VC
2008 and OSGeo4W
Alexander Bruy
alexander.bruy at gmail.com
Sat Sep 24 11:52:04 EDT 2011
Thanks for this links. I'll try to build bindings using this information.
2011/9/24 Even Rouault <even.rouault at mines-paris.org>:
> Le samedi 24 septembre 2011 15:43:57, Alexander Bruy a écrit :
>> Thanks, renaming cpl_config.h.vc to cpl_config.h solves the problem.
>> Now GDAL compiles.
>> Unfortunatelly, I can't build Python bindigns because Python in OSGeo4W
>> was built with VS 2003 and seems there are no downloads for this VC
>> version. Bad...
> http://svn.osgeo.org/gdal/trunk/gdal/swig/python/fallback_build.bat could
> perhaps be usefull. Credit must be given to Frank, because I just read that
> suggestion in the following thread :
> http://lists.osgeo.org/pipermail/osgeo4w-dev/2011-September/001430.html
> Or you could use a more modern version of python, that would like VC 2008,
> instead of the one bundled with OSGeo4W.
> Otherwise you might consider using http://www.gisinternals.com/sdk/ that has
> binary builds with a lot of dependencies and that support various python
> versions (>=2.6), and also the -sdk to redo/customize the build yourself if
> needed.
>> > Le samedi 24 septembre 2011 14:01:35, Alexander Bruy a écrit :
>> > The line numbers in the error message makes me believe that, for some
>> > reason, the cpl_config.h that gets used is the Unix one and not the one
>> > coming from cpl_config.h.vc. So I'd suggest you delete port/cpl_config.h
>> > and start building again.
>> Thanks
Alexander Bruy
