[gdal-dev] Masking issue
Chaitanya kumar CH chaitanya.ch at gmail.com
Tue Apr 3 13:35:17 EDT 2012
Oyvind,
One easy method is to create a vrt file with an alpha band for the original
tiff. You can use this to create a compressed raster file that will be
transparent at nodata pixels.
gdalbuildvrt -addalpha
http://www.gdal.org/gdalbuildvrt.html
On Tue, Apr 3, 2012 at 5:26 PM, Oyvind Idland <oyvind.idland at gmail.com>wrote:
> Hello,
> I got one problem: I have a bunch of uncompressed TIFF tiles, which I am
> converting to compressed GeoTiff. I would
> like to mask away the rgb(0,0,0) values.
> However, when I use NODATA on my VRT dataset, there are JPEG artifacts
> around the edges when rendering.
> Is it possible to generate a transparency mask based on NDATA before
> compressing, or is there any other/better way of
> doing this ?
> thanks,
> - oyvind
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120403/9e33b519/attachment.html
