[gdal-dev] RPC Transform Error: ERROR 1: latitude or longitude
exceeded limits
Claire Porter
claire.porter at gmail.com
Mon Apr 9 10:12:28 EDT 2012
Dmitry (and the list),
Using the warp options you suggested does not make a difference. Even
SAMPLE_GRID does not significantly change the output. I also tried using
wgs84 as the output coordinate system in case it was an issue of being
projected into Polar Stereographic: no luck.
I copied the relevant functions from gdal_rpc.cpp into python order to test
the RPC calculations independant of the warping functions and any
projection system. I used a sampling grid over the whole extent of
whatever test image and found that the RPCs do not converge for any part of
the error-prone images In fact, with each iteration the offset from the
original pixel gets further and further from zero (alternating sign each
iteration).
>From these tests, I am guessing that the issue is not the sampling or the
projection system. Since other software packages can handle these images,
I assume then that the issue is in how gdal is managing the RPCs. Any
ideas?
Many thanks,
Claire
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120409/27d3952d/attachment.html
