[gdal-dev] Fastest way of reprojecting from VRT ?
Oyvind Idland oyvind.idland at gmail.com
Fri Apr 13 08:04:14 EDT 2012
In my case, I got a VRT consisting of about 20 GeoTIFFs, where each tile
has overviews in them.
I did write some sandbox code, and tried the gdalwarp tool. Both are
equally slow.
There are earlier posts related to this aswell.
Den 13. apr. 2012 13:36 skrev "Even Rouault" <even.rouault at mines-paris.org>
følgende:
> Selon Oyvind Idland <oyvind.idland at gmail.com>:
> > I am currently using GDAL 1.8.0, and have found that reprojecting VRT
> > datasets can be incredibly
> > slow (several minutes in my case). I believe there are bugs/tickets
> related
> > to this issue.
> > I am only interested in reprojecting arbitrary datasets (or portions of
> it)
> > into a screen size window, on the fly.
> > What is the most optimal way of doing this ?
> > Should I read the desired window first, and then reproject it ?
> There are many potential causes that could explain an excessive slowness.
> Without precise facts, it is hard to tell which strategy could improve
> that.
> > - Oyvind
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120413/511736fd/attachment-0001.html
