[gdal-dev] Call for discussion for "RFC38 - OGR Faster Open"
Sat Apr 14 16:21:53 EDT 2012
Even,
I am generally in favor of this, but I aspire in GDAL 2.0 to migrate
OGR to using GDALDriver mechanisms which would include being based
around GDALOpenInfo.  I am not sure if it is better to make the
GDALOpenInfo change as part of that broader effort or as a distinct
RFC and work item.
Best regards,
Frank
On Sat, Apr 14, 2012 at 1:11 PM, Even Rouault
<even.rouault at mines-paris.org> wrote:
> Hi,
> This is a call for discussion for "RFC38 - OGR Faster Open" :
> http://trac.osgeo.org/gdal/wiki/rfc38_ogr_faster_open
> Summary
> It is proposed that the OGR datasource opening mechanism relies on the
> GDALOpenInfo class, already used by GDAL drivers, to speed-up datasource
> opening. The speed-up is due to the fact that the file passed to OGROpen() will
> be opened and stat'ed only once, whereas currently, it is opened and closed as
> many times as there are OGR drivers. This should be particularly beneficial for
> network filesystems, or when trying to open a file that is not a OGR datasource
> at all.
> E.g., trying to open a file that is not a OGR datasource currently requires 45
> file opening or stat operations :
> $ strace ogrinfo -ro NEWS 2>&1 | grep NEWS | wc -l
> 45
> It is expected that if/once all drivers are migrated, it will decrease to 2
> operations only.
> Best regards,
> Even
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
and watch the world go round - Rush    | Geospatial Software Developer
