[gdal-dev] gdal_translate alters NITF's metadata
Shawn Gong
SGONG at mdacorporation.com
Fri Apr 20 17:28:05 EDT 2012
Thanks Frank.
We also find that NITFCreateCopy() doesn't copy the 4 corner GCPs, only the geotransform.
We'll take a look at your suggestion and report back.
Shawn
________________________________________
From: fwarmerdam at gmail.com [fwarmerdam at gmail.com] On Behalf Of Frank Warmerdam [warmerdam at pobox.com]
Sent: April 20, 2012 12:35 PM
To: Shawn Gong
Cc: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] gdal_translate alters NITF's metadata
Shawn,
I see the values you get for NITF_ISORCE and NITF_IDATIM
are the default ones in the NITF Create code. Looking through
the NITFCreateCopy() code in nitfdataset.cpp, it only seems to
copy a few selective metadata items from the source dataset to be
creation options when creating the header of the new one. ISORCE
and IDATIM are not amoung them. I'm not sure why it is so selective.
I'd suggest we open up this loop to copy more header values:
/* Copy over other source metadata items as creation options */
/* that seem useful. */
char **papszSrcMD = poSrcDS->GetMetadata();
int iMD;
for( iMD = 0; papszSrcMD && papszSrcMD[iMD]; iMD++ )
if( EQUALN(papszSrcMD[iMD],"NITF_BLOCKA",11)
|| EQUALN(papszSrcMD[iMD],"NITF_FHDR",9) )
char *pszName = NULL;
const char *pszValue = CPLParseNameValue( papszSrcMD[iMD],
&pszName );
if( CSLFetchNameValue( papszFullOptions, pszName+5 ) == NULL )
papszFullOptions =
CSLSetNameValue( papszFullOptions, pszName+5, pszValue );
CPLFree(pszName);
Perhaps you could prepare a patch and test it and then submit it?
Best regards,
Frank
On Fri, Apr 20, 2012 at 9:20 AM, Shawn Gong <SGONG at mdacorporation.com> wrote:
> Hi list,
> I use gdal 1.9.0
> I have a NITF image that has 12 bands. The first 8 are I and Q of a quad-pol complex.
> I ran "gdal_translate -of NITF -b 9 -b 12 -b 10 -b 11 pp1.NTF test" to get rid of them and keep the last 4 magnitude bands.
> However the NITF tags are altered, e.g. the NITF_ISORCE and NITF_IDATIM
> Have you seen this?
> I also see "Warning 1: FHDR=NITF02.1 not supported, switching to NITF02.10." Can this be the cause?
> Thanks,
> Shawn
> gdal-dev mailing list
and watch the world go round - Rush | Geospatial Software Developer
